Home > General & Technical (L663) > Speed Limiter |
tooslo964 Member Since: 25 Jun 2020 Location: Aberaeron Posts: 42 |
Had this happen on our defender. Happily doing 70 on a dual carriage way. There was a parallel road to us and we must have picked up a 30mph from that as we suddenly started to brake. Fortunately I could take over before the causing major issue with following traffic.
I also had an occasion when driving on a 60mph A road, no speed limiter involved, but the car suddenly decided we where going collide, with only what I could assume was a car parked in a layby, very heavy braking, following traffic most concerned with finger signals and horns. Don't get me on to headlights dipping for every house it sees , resorted to that on manual now No way on earth is this technology ready, unless maybe you live in a city ! Apparently it's called progress, or to gradually force us away from driving |
3rd Feb 2023 7:20pm |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
I've had this with our VW - it picked up a sign from somewhere on the motorway and started braking from 70 down to 30 for no reason! Obviously as soon as you touch the pedal it stops braking, but it's pretty disconcerting!! I turned off that 'feature'!
3rd Feb 2023 7:26pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
After the last software update my car tells me that this is no longer available periodically - I’ve never used it anyway. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
4th Feb 2023 12:16pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3404 |
Yeah I get, though only tells me via the Pivi screen, bus as with you I never use it. 24MY 90 D250 HSE, Tasman Blue
4th Feb 2023 1:23pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
Same with me , happens on a regular basis, but also found that the map info can be the problem. I had a volvo before and both that and the defender use Here maps. There is a stretch of road near me which is a thirty limit with no 20 signs anywhere about. My volvo used to suddenly slow down to 20 for no apparent reason , thought that was over until driving the defender and it did the same thing. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
4th Feb 2023 3:19pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Speed limiter has been like this for as long as remember
However if you stamp the accelerator to the floor, it will over-ride the speed limiter, it’s a feature Mike |
4th Feb 2023 5:21pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2643 |
Not quite what i started the post as but this in an interesting read.
https://theintercept.com/2023/01/10/tesla-...autopilot/ |
4th Feb 2023 8:25pm |
County V8 Member Since: 07 Jun 2021 Location: UK Posts: 147 |
I live on a de restricted country lane (60mph) some one stuck a 30 mph sticker on their wheelie bin caused chaos until the Police made them remove it.
Good luck with technology . |
4th Feb 2023 11:38pm |
San Marco Member Since: 18 Jul 2023 Location: Hesse Posts: 26 |
I was always wondering, why Land Rover has an adaptive speed limiter (adjusting max. speed according to traffic signs) but doesn’t use this feature within ACC (adaptive cruise control), while other companies do. After your statements this unexpected behaviour might be even more critical on ACC, where you‘re likely off the pedal - so overriding takes just a few seconds more, what might be too much in some cases… so far my theory… what’s your thoughts on this? Is there any official information why JLR is not using speed recognition for ACC?
cheers guys! |
12th Sep 2023 10:57pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 820 |
During handover, the sales guy had the best recommendation, switch speed limiter off, which we did.,
Avoids applying the brakes when it sees advisory speed limits or picking up other signs on the side of the road for things like car park entrances etc.. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
13th Sep 2023 4:06am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2836 |
l am not sure my base specification 90 Commercial even has the speed limiter feature. lt has on one occasion done an emergency stop while l was turning right, fortunately nobody behind me, obviously didn't like the look of the car coming the other way.
13th Sep 2023 7:00am |
RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 592 |
The feature is a bad idea I had a VW and Cupra with it and they were worse at handling it than JLR cars. My RR seems to be worse (or more sensitive) than the current 110 loaner it picks up speed signs off the back lorries which is a problem. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
13th Sep 2023 7:15am |
