Home > Td5 > LT230 rear output seal - installation depth?
Lionel
Australia
I have a 110 TD5 Defender, MY2002.
Dealing with changing the LT230 rear output oil seal, I am interested in whether the new seal should be drifted in so that it contacts the bearing track, or should it be a shallower depth.
There seems to be different opinions in some of the theads covering this topic.
Any information would be greatly appreciated.
Regards,
Lionel
Post #980229 29th Jan 2023 12:00am
rallysteve
If you look in pg60 of the rebuild manual (https://www.google.com/url?sa=t&source=web&rct=j&url=https://duud.ee/LR-manualid/LT230T_Transfer_Box_Overhaul_Manual.pdf&ved=2ahUKEwjy0despuz8AhWgRkEAHeh1DsYQFnoECBMQAQ&usg=AOvVaw0uKIdBFAHbZZ4vQSgnSnqZ)
It implies that the seal should be installed deep enough so it 'just touches the circlip'.
Post #980240 29th Jan 2023 7:57am
Lionel
Australia
Thanks Steve, that's very helpful.
Cheers,
Lionel
Post #980423 29th Jan 2023 11:13pm
geobloke
As Steve has said. If however you are re-using your output flange then pay attention to where the original seal ran, check the flange is not scored. If there is any wear then adjust the seal fitment depth a little so the sal runs on a fresh part of the flange.
Nothing worse than doing the job only for oil to seep past the seal.
Post #980472 30th Jan 2023 12:22pm
Lionel
Australia
Thanks geobloke,
I am using a new flange, so its probably best to stick to the manual instruction, with the seal "just touching the bearing circlip".
Hope it goes well this time.
Cheers,
Lionel
Post #980884 1st Feb 2023 9:59pm
