Home > Technical > brake caliper bolts
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
brake caliper bolts
i have broken a caliper to axle bolt. its a 300tdi with the metric 12 point head bolts so m12 fine thread. i am confused as to which tap i need to clean all the bolt holes out with. ant ideas as there are various ones m12x1.5 m12x1.00 .
Post #980304 29th Jan 2023 1:34pm
Dinnu
To my knowledge they are 1.25mm pitch.
If you managed to extract a bolt without breaking, you can count 12 thread pitches , so if the distance between the 1st and the 13th thread is 15mm, then it is a M12x1.25. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #980309 29th Jan 2023 2:09pm
Screbble
Re: brake caliper bolts
Those 12 point head bolts are notoriously problematic.
I’ve have to grind flats on them it the past to get s decent spanner/wrench on them.
If it is snapped, but you have the caliper removed, then you can probably do the same.
When you do remove it, it would be worth cleaning out the threads with a modified bolt or thread chaser as opposed to a tap.
Hope you sort it 👍
Post #980313 29th Jan 2023 2:28pm
paul 123
thanks
Post #980329 29th Jan 2023 3:58pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
This was my experience which may be worth a read. The caliper bolts have two different threads, the finer thread is which I believe was used from the 300tdi/24 spline differential. The coarse thread was the 200tdi/10 spline differential.
I bought myself a set of thread chasers and I am happy I did. They just clear out the threads rather than recutting them. I have used them on many things and the set came with m6, 8,10 & 12 in fine and coarse.
https://forums.lr4x4.com/topic/111496-remo...zed-bolts/
Post #980398 29th Jan 2023 8:56pm
paul 123
had a bit of luck with the broken bolt. i drilled through the centre of the bolt from the disc side disc and hub removed. the bolt then came out with an easy out i then cleaned the thread with a bolt and plenty of oil. so all fixed.
Post #980504 30th Jan 2023 3:08pm
Screbble
Great result Thumbs Up
Glad you got it sorted.
I’ve never had much luck with easy outs on caliper bolts and my Irwin stud extractors didn’t succeed either.
Now you can get on with the job in hand 👍
Post #980574 30th Jan 2023 10:23pm
Mossberg
Well done on getting them out. The learning never stops!
Post #980587 30th Jan 2023 11:21pm
paul 123
now the rest of the rebuild can go on
Post #980603 31st Jan 2023 9:54am
