Home > General & Technical (L663) > Retrofitting a heated Alcantara Steering Wheel |
nowrxo Member Since: 10 Sep 2015 Location: None Posts: 79 |
Powerful do offer an upgrade kit for the Evoque, so I used the part numbers listed there to try and find some equivalents for the Defender.
There's a parts diagram here for the Defender steering wheel here: https://parts.landroverpalmbeach.com/showA...odelYear=0 This lists the heated steering wheel, a loom and a switch. There are multiple variants for each, so you'd need to make sure you choose the right one. The "heated slip ring" seems to be called a "clockspring", of which there are four variants: https://parts.landroverpalmbeach.com/produ...odel=90556 There are two "heated" ones - one for cars with fog lights and one for those without. |
21st Jan 2023 4:41pm |
overlanding_defender Member Since: 15 Dec 2022 Location: Cobham Posts: 8 |
This post has been edited by the site administration team: commercial spam
27th Jan 2023 10:21pm |
Carpathian Diem Member Since: 21 Oct 2022 Location: Lincoln Posts: 15 |
I got it done a little while ago, had the paddleshifters added too. Can point you in the right direction.
Click image to enlarge |
28th Jan 2023 2:21pm |
