![]() | Home > Technical > Clunking on full lock |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 869 ![]() ![]() |
Clunking or clicking and is it when you are moving? Could be CV joints wearing. If its a real clunk try wobbling the steering wheel back and forth while someone looks under the front, look at the balljoints for movement, the drop arm and the steering box.
Might also be worth checking the swivels are fully bolted to the axle tubes, have seen these come loose before. Visual check only from the front of the axle. |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
Sounds like you need to put grease into the front hubs
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 ![]() ![]() |
Hi guys.
The clunking noise is when the car is stationary as well as moving. It sounds like someone hitting something with a hammer. 300tdi 90 1996. |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 839 ![]() ![]() ![]() |
Panhard rod bolts loose, or panhard bush failed?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Check the state of the steering damper.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 814 ![]() ![]() ![]() |
Check the universal joints on the column
The fact it is happening at full lock even when stationary sort of rules out drivetrain.
I still think it is something like the panhard rod moving when the swivels have turned to full lock but the steering is still pushing/pulling on the axle. Maybe one of the bolts isn't quite tight. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
My thoughts too. Years back I had the southdown lower axle guard fitted to a 90. It was such a tight squeeze (along with A/R bars) that once the panhard rod bushes got a bit worn, the metal parts would soon knock together. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2166 ![]() ![]() ![]() |
I’d be surprised if you can’t locate the issue if you have another party to operate the steering whilst you are underneath - or vice versa - ensuring the vehicle wheels are chocked of course.
Could be any of the above and any ball joint. |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
it could be many things from a simple worn bush to something more serious.
time for a trip to a 4x4 workshop..... |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2323 ![]() ![]() ![]() |
Sounds like panhard but would have thought 90roy would have spotted this when his helper was turning the wheels whilst he inspected as you can really see it move! > 110 XS Double Cab
Thanks chaps.
I shall check the panhard rod.may get a new one for good measure if they're not too expensive. R 300tdi 90 1996. |
