Home > General & Technical (L663) > does 130 have an active rear differential?
cestor
Israel
playing around with different 130 build options and I couldn't see that a rear locking ("active") differential was an option even with the off-road or advanced off-road packs. Is this because it is standard or they have done away with it. Hopefully not the latter as in combination with the reduced departure angle it means no proper off-roading...
Post #978973 20th Jan 2023 1:39pm
David007
I just picked a random 130 in the configurator and can still see the electronic active diff in the off road pack, is this the same as your looking for?
Post #978986 20th Jan 2023 3:01pm
cestor
Israel
so this is what I see!
this is the link to the build https://build.landrover/9255F98C
BTW - I also tried with a 130 x-dynamic d300 hse like in your screenshot and I still don't see the active differential option.
Post #979181 22nd Jan 2023 7:18am
Tim in Scotland
Just built a 130 HSE on the configurator - no rear diff as standard BUT you can still spec it without the other bits of the Off Road Pack if you look into the Capabilities and Dynamics section of the Options
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #979210 22nd Jan 2023 10:53am
cestor
Israel
interesting - if you see my screenshot above, there is no capabilities option on the left. I guess this is the rest of the world configurator and there is no rear diff option for some reason. crazy.
Post #979212 22nd Jan 2023 10:56am
Tim in Scotland
I set the configuration to Region - Europe
Market - U.K.
whenever I go into it.
Those choices are right at the top of my screen whenever I go into LandRover.com website
Click on the top of the page and this page opens
Post #979215 22nd Jan 2023 11:07am
