Home > In Car Electronics > 10AS Upgrade
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
10AS Upgrade
Has anyone else done this 10AS upgrade, how did it go? did everything work after?
TIA
https://www.ebay.co.uk/itm/163640330244?ha...R8Dum-K4YQ
Post #978716 18th Jan 2023 8:15pm
rallysteve
I did it years ago (possibly even using thay exact kit) and it worked perfectly straight away. Easy enough even with a basic soldering iron as they are 'through hole' components rather than surface mount.
Post #978726 18th Jan 2023 8:55pm
Ianh
That eBay link seller is the company that does repairers and upgrades to 10as units. https://www.technozen-electronics.co.uk/la...-services/ so the parts should be quality items.
As long as you have a nanocom or equivalent you should be able to program the central locking function once you have the looms and actuators in place.
Post #978730 18th Jan 2023 9:11pm
mrfirepro
Thanks for the replies, my project donor is a farm truck without Central locking, but have retrofitted complete XS loom so hopefully should be OK. Just down to my quality soldering now....
Post #978737 18th Jan 2023 9:51pm
Oooh tempting.... Thumbs Up
Post #978785 19th Jan 2023 10:09am
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
I had this done by the same eBay person on his site https://www.technozen-electronics.co.uk/la...-services/
Took the unit out. Sent it off and within a couple of days it was back and fitted again.
Works as if it always had CL
Post #978895 19th Jan 2023 9:22pm
rallysteve
My 02' TD5 was totally basic spec and required no programming of the 10AS to enable the central locking. It just worked as soon as the components were added.
Post #978898 19th Jan 2023 9:48pm
Ianh
That’s interesting Steve, there is a setting called “CDL when arm” which is set to active when CDL is installed. I would have thought that would be set to inactive if the CDL relay and varistor were not fitted, but suppose it may be set as active even if they are not, which would explain why yours worked without the need for the 10AS to be programmed. So that makes it simpler for the OP.
Post #979220 22nd Jan 2023 12:44pm
chrisc2306
Scotland 2011 Defender 90 Puma 2.4 CSW Zambezi Silver
I retrofitted central locking to my puma a few years back and done a write up here for it, it only required soldering one connection onto the 10as to get it to work with the fob
https://www.defender2.net/forum/topic70649.html
Post #979949 26th Jan 2023 11:59pm
