Home > Puma (Tdci) > Diff lock cannot be selected
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I cannot select diff lock but it’s about 7 years since used it.
Are there any things I can do to be able to free this.
I can select high and low easily.
I believe lack of use is my problem. Own goal.
Anyone had this problem before?
Post #978402 16th Jan 2023 8:25pm
geobloke
Ahhhhh Use it or lose it my friend...
It is likely that the C-clip that connects to the diff lock actuator has corroded in place. It is a common thing on Land Rovers that do not get used often.
Circled in red.
Whatever you do... Do NOT force it...
Post #978403 16th Jan 2023 8:34pm
Crofter
Thanks your right use it or lose it.
I will have a look to see what is involved not been into this part of my Landy so far.
Much appreciated thanks.
Post #978404 16th Jan 2023 8:41pm
geobloke
The first step is going to be removing the matting and transmission tunnel then you can look down on to the linkage. You might be able to work it loose with some penetrating oil and a little heat. If it is stuck solid then it looks like you cannot buy the bits of the linkage separately for the Puma. So fingers crossed you can work it loose Thumbs Up
Post #978408 16th Jan 2023 8:54pm
Crofter
That sounds a good plan.
I was looking at the Haynes manual and it tells me nothing.
I will do a bit of exploring tomorrow in day light
You have been a great help thanks.
Post #978410 16th Jan 2023 9:01pm
geobloke
You are welcome. any problems just shout out, there are loads on here who can help. Thumbs Up
Post #978413 16th Jan 2023 9:17pm
Naks
7 years without using the CDL???? Shocked --
Post #978424 16th Jan 2023 10:18pm
geobloke
Happens more often than you would think...
Post #978425 16th Jan 2023 10:20pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
My old neighbour always said to stick it in reverse and try lock the diff at super slow speed backwards, never had the bottle to try it myself, could never fathom that reasoning Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #978428 16th Jan 2023 11:03pm
Ianh
You can get at it from under the vehicle , with a good torch you can see it and spraying the linkage shown with proper penetrating oil, I.e plus gas, waiting about 10 mins , then doing again, waiting 10 mins then trying to wiggle the lever without too much pressure may get it moving. Once it is moving spray more penetrating oil and see how free it’s moving with someone else moving the lever while you are under the vehicle. That way you can see all the moving parts that need lubricating. When all working use some light spray grease on the linkage to keep it lubricated.
If unsuccessful you will likely need to get at it from above as per geoblokes instructions.
Post #978432 16th Jan 2023 11:51pm
Why would doing this require "bottle"? I don't understand!
Post #978463 17th Jan 2023 10:04am
Muddybigdog
Bloody good track record of things going bang that ends up costing me more Big Cry Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #978479 17th Jan 2023 10:55am
Crofter
Thanks guys I had hoped to get on it today but will tomorrow.
I appreciate the help.
Post #978571 17th Jan 2023 6:26pm
