Home > In Car Electronics > Best location for an outside air temp probe?
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
As above, I’ve fitted RedArc gauges to my 2012 Defender 110.
Some of these gauges have the ability to provide external (or internal) ambient air temps and have a water proof/UV stable temp probe on a long cable.
I’m after suggestions as to where to route/locate the temp probe to provide a realistic outside temp, I.e not effected by direct sun vs reading ambient temp. I have a Safari snorkel fitted to my one 110, and so thanks in advance for any advice on how/where you’ve routed and located yours, and the benefits/issues.
Best wishes all.
Ken
 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #978115 14th Jan 2023 11:50pm
ak615
I mounted mine behind the drivers side headlight only issue is when vehicle is stationary the heat from the engine affects the reading it soon gives the correct reading once moving again.
Post #978128 15th Jan 2023 9:00am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I’ve placed mine in the airintake box. The reasoning behind that was there’s a lot of airflow going through and it’s on the inside so never direct sunlight.
And as far I can see it’s working as intended after the first 5 minutes. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #978132 15th Jan 2023 9:26am
