Home > General & Technical (L663) > Raised suspension when going through floods
AndrewS
We have a bit of water on the roads around North Herefordshire. My Defender decided to raise itself clear of the water. Took a pic to show how high it is compared to a T6.
 130's have feeling's as well you know Smile
Post #977945 14th Jan 2023 12:01am
Tim in Scotland
It will also close the vent flaps in front of the radiator and activate the depth gauge if you select the Wade mode in the TR system Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #977967 14th Jan 2023 10:10am
lightning
Lucky you, having air suspension!
My 90 seems to sit quite low, but with the 90cm
maximum wading depth it's still going to be better than my old 110. l guess l won't have "wading mode" either on my base specification 90 Commercial so probably better to avoid deep Fords and river crossings
Post #978035 14th Jan 2023 5:41pm
J77
On coils it’s only 85cm, but the coil suspension is more than up to the job when the going gets rough. 24MY 90 D250 HSE, Tasman Blue
Post #978067 14th Jan 2023 7:07pm
peanutbob
There is also a super extended mode - see below which is useful when grounded . It’s not specific to the latest Defender as it was available from the D3 onwards :
Make sure the relevant warnings and cautions have been read and fully understood before adjusting the electronic air suspension.
Extended mode is an automatic suspension height setting that raises the vehicle to assist maneuvering in the event that the vehicle is:
Grounded in severe off-road conditions.
Lowered onto an obstacle.
Wading in deep water.
Driving in narrow ruts.
The instrument panel displays a message and the off-road indicator lamp on the front control panel flashes to confirm the vehicle is in extended mode.
Note: Extended mode cannot be selected manually.
The vehicle can be raised higher when in extended mode, if required. To further raise the vehicle:
1. Press and hold the brake pedal.
2. Press and hold the up button (3) on the front control panel for longer than 3 seconds.
Post #978090 14th Jan 2023 8:31pm
AndrewS
Like this.
I didnt make my self clear, I was pointing out that it automatically lifted above the the first lift and this wasn't extended mode when you can go up again as described. So by the looks there are another 2 lifts to go after it was shown in my pic. 130's have feeling's as well you know Smile
Post #978126 15th Jan 2023 8:52am
tooth_dr
Northern Ireland
Mind went into extended lift mode whilst in town. By the time I pulled in to get a photo it went down again. It was ridiculous, people were actually looking at it wondering WTF lol
Post #978127 15th Jan 2023 8:59am
Is it clever enough to check for headroom above the vehicle before doing this? A flood under a low bridge, etc., could be unfortunate.
Post #978145 15th Jan 2023 10:28am
AndrewS
No it's not but I am, I wouldn't attempt to go under a bridge that had a head room less than 2.200m and was flooded. Having said that I probably would I'd lock it in access mode first Thumbs Up Rolling with laughter 130's have feeling's as well you know Smile
Post #978196 15th Jan 2023 3:38pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Yes my car has done this a couple of times when driving through fords, I wouldn't have classed the fords as deep enough to warrant raising the suspension but the car obviously thought it needed it Confused Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #978198 15th Jan 2023 3:53pm
Sepp
Germany
Extended Mode on the New Defender.
Post #981472 6th Feb 2023 10:51am
markb110
Just be thankful you weren’t arrested for lewd behaviour…… Whistle
Post #981478 6th Feb 2023 11:52am
XplusYplusZ
I don't fancy testing it, but apparently it's sensitive enough to avoid crushing someone working underneath it..
I guess it knows how much weight should be on all 4 wheels and when it starts to float, it tries to tip-toe.
Post #981491 6th Feb 2023 1:49pm
Defendit..
Netherlands
This no longer works on our L663's , thanks to the SOTA - programmed out. No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #981503 6th Feb 2023 3:44pm
stevemfr
France
Where did you read or hear this?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #981508 6th Feb 2023 3:57pm
