![]() | Home > General & Technical (L663) > Side Lights Operation |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17603 ![]() ![]() ![]() |
I'm so glad I'm not the only person who has zero tolerance for cars which refuse to allow legal and sensible use of sidelights. I'm also very intolerant of people who on learning this tell me "you shouldn't drive on sidelights alone"! There's a word for these people but this is a family friendly forum.
How can you remain legal when reversing during the hours of darkness in a modern vehicle with auto headlights? I've not yet met a car designed by someone smart enough to turn off the headlights when reverse gear is selected. How does a software engineer in some European factory know more about my driving conditions than I do. Ridiculous. How do these systems get through type approval? Has the world gone entirely mad? |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 436 ![]() ![]() |
So after almost 18 months, this problem isn't solved yet. See my earlier post.
https://www.defender2.net/forum/topic77970.html In the CCF this should be changeable, who can take a look ? By the way, for me sidelights are the American Orange and Red lights on the left and right side of the car. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1217 ![]() ![]() |
" ...... for me sidelights are the American Orange and Red lights on the left and right side of the car."
That may be your view, the Orange and Red lamps ...... are Marker Lamps, not side lamps. I had them fitted on a Disco 300 I had years ago. I also had the Orange and Red (front and rear side facing) lamps working on my Disco 2 Td5. Further I added a Red (rear side facing) lamp to a FL2. I believe side lamps, marker lamps and DRL are all getting confused, or integrated ?? |
forest172 Member Since: 01 Nov 2012 Location: derbyshire Posts: 355 ![]() ![]() |
I`ve just taken delivery of a D250 HT and you can turn the sidelights on and turn auto off. It then doesn't override your choice 2015 90SW Heritage MY16, 2016 90SW XS MY16 (123rd b4 the last build) & RRS HSE MY15
Dicky1961 Member Since: 25 Mar 2022 Location: South Yorkshire Posts: 145 ![]() ![]() |
Finally got an answer from LR regarding my sidelights problem.
![]() “Sorry sir you cannot manually select the sidelights to come on and stay on, and It’s not something that can be configured either. You’ll just have to live with it” Utter rubbish design. ![]() |
My my22 90HT had a dealer update and now I can use the sidelights as you would expect 2015 90SW Heritage MY16, 2016 90SW XS MY16 (123rd b4 the last build) & RRS HSE MY15
Hi forest172, can you give me any guidance as to what the update involved with your car?
Does your car have the premium led’s the same as mine? Seems ridiculous that one dealership can and another can’t solve the problem. Cheers Dick |
Yeah I have signature DRL, not matrix. My car asked for an early oil change so I took it and they said it also needed an update. I’ve never mentioned the sidelight problem. But since it’s been in I can now turn the side lights on and drive just with those on. Before the car used to keep changing to lights on / DRLs on if I turned the sidelights on manually. Something definitely different 2015 90SW Heritage MY16, 2016 90SW XS MY16 (123rd b4 the last build) & RRS HSE MY15
Thanks for that. I’ll have to try again next time I’m in the service department.
steam_simon Member Since: 24 Sep 2022 Location: London Posts: 92 ![]() ![]() |
Spot on, and yes. |
JonathanP Member Since: 01 Jun 2024 Location: Barnard Castle Posts: 24 ![]() ![]() ![]() |
Hi
Just to let you know my 110 D250 X Dynamic SE ( according to Topix with Headlamps, Matrix LED, Signature ) Manufacture July 2023 but is a 24MY, still has Side lights that are switched off when the DRL's come on. I bought it as an ex demonstrator on 06 June 2024, apparently with the latest software, but managed to use the infotainment system to do another update to the car last week and it still switches the side lights off. No idea how to keep them on. You can see the green warning lamp on the dash switch off after you have driven a very short distance. The rear lights switching off have been witnessed on separate occasions by my wife and I as the car is driven down our street |
I have posted this before on a different thread......
What you require is to cut into the rear lamp cluster, where you will find a 5-wire cable form that links the two circuit boards which control the smaller and larger lamps. I can NOT advise anyone to do the same, as if you don't know what you are doing you could destroy both sets of lamp clusters. Sorry. ![]() Click image to enlarge |
