![]() | Home > Maintenance & Modifications > 3D Printed stuff! |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
Have a look at Thingiverse, loads of stuff to print although not a lot aimed at Defenders
![]() https://www.thingiverse.com/search?q=defen...t=relevant Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1043 ![]() ![]() ![]() |
What about printing replacement corner cappings for the rear corners? They've no structural need, just cover up the join between two panels. Always go rusty, so a plastic replacement would be ideal. I think you'd need to use plastic plugs to hold them in place as rivets would break the plastic.
Plain black would be ideal. Am I missing something silly? |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1385 ![]() ![]() ![]() |
Print yourself a series one!
https://www.thingiverse.com/thing:3750406 Euro-Leafing to infinity and beyond..... |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Got into 3D printed about 3 years ago and learnt how to design stuff in Fusion 360. To get the most from your printer I would strongly suggest learning to design yourself. Thingiverse is ok, but designing a solution yourself is more rewarding.
I haven’t printed anything for the defender but have printed a battery cover for my other car amongst other things |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Totally agree with this. If I just wanted to print other peoples items then its probably easier and more reliable just to buy that stuff.
I enjoy designing stuff, I used to do it with sheet metal all the time (was my job) - but that was 2D and folded. Learning 3D is going to be the aim, then I will be happily doing my own stuff, though I am not against using other peoples designs (with their consent). However, as I now have the printer it would seem silly having it then not using it to the max. I have bought lots of the little parts for Defender fixings and why buy those parts in future if they can be made as strong and cheaper on my printer than buying from China through a re-seller? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Or bigger/better:
https://3dsets.com/product-category/3dprin...x4-lineup/ 02' 110 TD5 Double Cab Rebuild Thread |
Niels906 Member Since: 04 Jul 2020 Location: Bussum Posts: 44 ![]() ![]() |
are you able to 3d print a gear stick knob?
