![]() | Home > In Car Electronics > NOLDEN GEN2 Headlights |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 169 ![]() ![]() ![]() |
You need a switched live.
I decided the easiest way was to buy one of the cheap controllers that sense battery voltage and use that to drive the DRL. I got the feed for this from the alternator.. I did not bother with a sidelight feed to dim the DRL when the sidelights are on, TBH i never run with just sidelights so didn’t see the point… |
Same here. Bought a simple DRL controller and wired the DRLs through that.
https://www.amazon.co.uk/gp/product/B084Q5...&psc=1 |
lakes Member Since: 08 Jan 2023 Location: Lake District Posts: 22 ![]() ![]() ![]() |
Cheers I’ll get one ordered. Saying that I did wire the DRL to a perm supply and when I turned the headlight on the DRL turned off. So technically if I change perm supply to a switched live won’t that give the same results as a controller?
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 342 ![]() ![]() ![]() |
It sounds from your description that the headlamp unit itself takes care of switching the DRL off when the lights are switched on, so all you need to do is find a switched live and wire that in.
On my Td5 there is a loom by the brake master cylinder which has a white/green wire, which indicates ignition live. for my DRL install I tapped into this wire to give me a supply to the relay I used to control my lights. A relay was necessary in my installation to cut supply to the DRL when the side lights were on. |
All done at last. Ordered a DRL controller from Amazon to make sure they dim when the sidelights come on.
Switched live taken from the thick orange cable running into the heater box, ground direct to battery. Line taken from the red sidelight feed to activate the DRL dimming function on the controller. All that’s left to do is wrap the wires in conduit to tidy it up. ![]() Click image to enlarge |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
does the Nolden Gen 2 also have built-in indicators? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
They don’t, they’re usual headlights plus DRL and position light if needed.
When I was looking at controllers you could get ones that turned off one DRL depending what way you were indicating and another made them strobe when you use the horn 😂 |
