Home > For Sale & Wanted > [SOLD] BAS2 RRC OBD Remote Remap Tool (PUMA 2.2)
notxal
United Kingdom 2014 Defender 90 Puma 2.2 HT Aintree Green
SOLD
Please be aware you have to additionally purchase any chosen map you want to use on your own vehicle. Costs, instructions and descriptions are on the BAS website or contact Pete directly, he's very helpful.
Go to the Bell Auto Systems website for further information.
BAS2 supported Defender 2.2L Functions are:
Apple iDevice & Android applications available for its control via the BAS2’s Bluetooth Smart enabled hardware.
PC & MAC application software for updating the BAS2 RRC tool remap file & and its firmware.
The remap file will be created and delivered via updater software on PC or MAC once created.
Diagnostic fault code reading and clear with worded text and snap shot data shown where present.
Live engine data logging with numerical and graphical views.
Save and export logs as PDF or CSV files.
DPF service functions, engine adaptation resets, clearing adaptive values.
Airflow meter reset, Fuel lift pump reset, Turbocharger replacement reset.
Storage of both original and tuned remap calibration files.
Injector coding reprogramming or replacement.
Defender 2.2TDCi oil counter reset.
Defender 2.2TDCi Renew security ID use for fitting new PCM’s
Flash programming of the engine ecu applying the latest engine calibration files.
Switch between BAS Remap standard and remapped calibrations at your leisure.
Possibility’s to purchase another Vin/Remap allowing use on a second car within your household.,
Post #977186 9th Jan 2023 9:26am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Would you ship to Spain? Also need to know if I can use it on my 2.4 with another map, and cost of that. So I’ll email Pete also with them questions Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #977203 9th Jan 2023 11:23am
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
I'll take it if it's still available.
Post #977573 11th Jan 2023 12:52pm
