![]() | Home > Technical > Radius Arms & Sizing |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
Hi,
Presumably you're asking about the width of the radius arm, the front bushes and the gap in the axle bracket that they fit. From 2012 Model year, CA chassis no. Arm width 44mm, Bush (inner metal tube length) and arm gap 52mm. Arm pt no LR041266 From 1994 LA to 2012 Arm width 44mm, Bush and gap 52mm. Arm pt no NTC7331, superceded by LR041266. Upto 1993 KA Arm width 38mm, Bush and arm gap 46mm. BUSH pt no NTC7307, Arm pt no NTC2705. I believe earlier arms, early 110 and Range Rovers had a few revisions on gap size and Bush diameter. 200 / 300 series Discovery may also have had some changes? |
aboduk Member Since: 09 Jan 2023 Location: Poole Posts: 2 ![]() ![]() |
That's fantastic - thanks very much for the explanation
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
What axle do you have. I replaced my 200tdi front axle with a 300tdi one so needed to replace them too. I managed to pick up a set from a 300tdi disco.
