Home > My Defender > 2.2 Brown 110 Utility
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
Here is my 2013 Puma, I only purchased it a couple of months ago and its had a pretty hard working life and had 120,000 on the clock when I bought it and came with a list of age related problems that need fixing.
So far the list of work done is…
    Replaced rear half shafts with LOF Solid HD Rear drive half shafts to fix the clunk
    Replaced the rear prop shaft with a Terrafirma one
    BAS 170 tune with BAS Intercooler and silicone hoses
    Added a Terrafirma rear wheel carrier
    Rewired the lights behind the heater controls (a really strange 5.8v problem that still needs proper investigation)
    RedBooster clutch servo assist (still needs to be fitted)
The list of things still to do includes
    Fix the strange 5.8v problem on the centre console lighting circuit
    Fit a LOF Road Clutch kit with solid output shaft
    Replace all fluids
    Clean injectors
    Find and fix the leak that causes a puddle to appear in both footwells after heavy rain
    Fit sound deadening and Exmoor carpet set, its a utility so has nothing at the moment
    Improve the ride and handling, I believe it has the HD springs, and the dampers have done 120k so a new set of springs and shocks would not go amiss
    Fix or replace the heated rear window elements
    Choose a roof rack
    Air filter box fan removal
    Centre exhaust silencer delete
    Bowler 18” wheels
    Masai front bumper
    Etc….
I’ll keep a record here of everything that gets done from now on
Post #977146 8th Jan 2023 7:41pm
JOW240725
Looks a great 110, good luck with your journey, sounds like its going to be well looked after Thumbs Up
Keep us posted. James
Instagram @suffolk_rovers
Post #977157 8th Jan 2023 8:41pm
