![]() | Home > General & Technical (L663) > Operator error, or needs looking at? |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2536 ![]() ![]() ![]() |
Sounds like the transmission maybe shifting down as you floor it. Maybe someone with a D250 could try and simulate flooring it from slow speed/light throttle and then comment. Defender 90XS SW
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3034 ![]() ![]() |
Yes it does shift down, the revs shoot up to about 3,000 and then engages suddenly with a lurch and surge of power
lf you are more careful with the gas pedal it is smooth. l just need to know if this is normal as l've always had manual transmission lt's actually better if you move the lever to the left "S" mode as it then doesn't keep selecting the highest gear possible |
I think its normal all of mine have done this, there seems to be a certain combination of factors when it occurs. I notice it happens in slow traffic or narrow roads when you are slowing down to pull over to let the on coming car go past. Then the on coming car pulls over for you to go past them. As you accelerate it takes off quite abruptly. 130's have feeling's as well you know
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
I've driven lots of autos and feel my D250 behaves oddly. It holds on to the gears and revs high when other cars would have changed down, does odd things going down hill where you have to accelerate to get it to change down and some times clunks at low speeds.
I'm adapting to driving to it but it just seems odd. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3460 ![]() ![]() |
My 90 D200 used to clunk, it went in for a 2WD warning popping up on the dash, part of the fix was a transmission software update, after that it was fine.
Being honest though my D200 felt better than my D250, the D250 seems to hold gears a lot longer. 24MY 90 D250 HSE, Tasman Blue |
To update this thread, the transmission smoothed out over time. So now l've done 4,000 miles it's fine.
The dealer said that it's "learnt the type of driving that l do" but whatever, it's okay now. |
