![]() | Home > Modifications & Maintenance (L663) > Advice please! |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Does it say what chemical is in it on the label?
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
It’s likely either an adhesion promoter, or actually something to delay the adhesive to give you time to get it into the correct position.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2536 ![]() ![]() ![]() |
As Co1 says it is an adhesive promoter.
Some instructions here that may help:- http://accessories-instructions.landrover....r/G2409771 Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3026 ![]() ![]() |
Thank you yes it appears to be adhesion promoter.
Better make sure l get the piece of trim in the right position first time because once it's on, it's not moving. |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
mark out the correct position up front on the bumper using masking tape (just outside the profile of the bumper protector) - this is how I did mine - it allows you to preposition it so its spot on before you go for the final stick on!
incidentally exactly how I positioned my door ding defender stripes onto the flat panel doors of my first D3 too (and later the positioning of the B-Pillar Black film and giant ISUZU letters on my old Isuzu DMAX tailgate) Sadly no photos of anything other than the B-Pillar black... Steve N | 21MY Defender ![]() ![]() ![]() |
Well, to update this l finally got around to fitting this part, and l've lost the tube of mystery substance so couldn't use it anyway.
However l cleaned the bumper top thoroughly and the part stuck tenaciously as soon as l placed it on, and l doubt it will ever come off. As above l used a few pieces of self adhesive draught excluder to guide the part and ensure l got the position correct. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
If you ever want to remove it warm it and then use either fine gauge fishing line or dental floss to cut the adhesive - a hair dryer is good for warming the surfaces. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Thank you l will remember that.
Hopefully it won't need to be taken off. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
I bought this:
https://www.powerfuluk.com/vehicles/land-r...-l663.html ![]() Thought it might give a bit more protection, particularly on the rear lip. I must say, the slopping, painted bumper is a liability when loading stuff in and out of the boot. My boot bumper protector has already saved me a lot of grief and damage. You can also stand on it. |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 276 ![]() ![]() |
Moo: I have this exact one fitted and the extra bit over the lip gives real peace of mind.
I can drag things out of the boot with gay abandon.. mountain bikes, suitcases, camping gear etc.. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
That looks great, l never saw that one! May have to upgrade! Best order some fishing wire to get the smaller one off
