Home > Puma (Tdci) > 2.2 or 2.4 ? and other questions |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8143 |
chassis is barely painted or anything else now days, so colour has changed, mostly due to lack of underseal!
i would be tempted to stay clear of anything with a DPF that doesnt get out and about for sustained periods. For jersey (30mph tops?) i wouldnt be buying a vehicle with a DPF. on the other hand you can remove them! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
1st Nov 2011 5:16pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Where did you get that impression from ??,, as it not The other way round 2011MY all the way California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
1st Nov 2011 6:29pm |
isv Member Since: 14 Feb 2010 Location: Worcestershire Posts: 8 |
I faced the small dilemma last month.. Went for the 2.4 110 XS Utility and very happy with it... I got a great deal and easily saved enough to pay for my fuel for the next couple of years...
1st Nov 2011 6:51pm |
Where? in my opinion 2.4 and 2.2 will be the same car.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Nov 2011 7:28pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
I think this is in reference to the 2.2 being fitted with a noise blanket/cover as standard. It said this in the original marketing blurb. |
1st Nov 2011 8:17pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4729 |
I find the 2.4 Puma quite refined and quite. Any quieter and I'd be able to hear the Mrs. think. Bad enough being able to hear her talk....... 1982 88" 2.25 diesel
1st Nov 2011 10:10pm |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
Thanks guys,
If the rumoured additional refinement of the 2.2 is down to an engine blanket then that would seem to be a bit of a non-event as I will fit a Noisekiller kit anyway. Brian Last edited by jerseyman on 2nd Nov 2011 12:08pm. Edited 1 time in total |
2nd Nov 2011 10:03am |
Nothing that you can not add on the 2.4........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Nov 2011 10:22am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2438 |
it uses less oil.......6.2l Puma 110" SW
............................................................. Earth first. Other planets later Last edited by MK on 2nd Nov 2011 2:52pm. Edited 1 time in total |
2nd Nov 2011 11:44am |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Find someone with a 2.2 transit and ask them if the DPF have shagged itself in Jersey as it's the same engine.
2nd Nov 2011 12:31pm |
? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Nov 2011 2:39pm |
That's exactly what I've asked the Dealer to do. Brian |
2nd Nov 2011 5:03pm |
Right I have just had the salesman on the phone about the 2.2 DPF issue.
He has told me that the 2.2 is the same engine as in the Freelander 2 and they are not having problems with the DPF on those. Now it is my understanding that it is not - unless the 2.2 engine in the F2 is also a Transit engine? When I queried it he says "that is what he was told by Landrover" Can anyone shed any light on this? Brian |
4th Nov 2011 11:35am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6628 |
Wrong - the 2.2 engine is NOT the PSA DW12 from the Freelander 2, it is a Ford Puma TDCi. The same basic engine as before. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
4th Nov 2011 11:37am |
