![]() | Home > Technical > Axle datum points |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 517 ![]() ![]() ![]() |
hi Folks,
Is their any datum points on the chassis that i can check my axle alignment with ? Shane |
I know of no such thing. But... Logic would dictate that the distance from the trailing arm outrigger to the trailing arm mounting holes on the axles should be equal left to right. Assuming all the bushes and bolts are in A1 condition that is.
Same for the front, but the radius arms. If all is equal then ![]() |
No worries
