Home > Wheels & Tyres > Largest tyre I can fit onto a 5.5 x 16 steel wheel?
m33ufo
Wales
Hello All.
Within reason, what's the largest tyre I could safely fit on this rim size? I don't what to change the rolling radius.
I'll likely be going with a KM3 or possibly an STT Pro.
Cheers Thumbs Up 110 DCPU
Mark
Post #976424 2nd Jan 2023 7:58pm
Grouse
These rims were fitted with either 7.50x16 for 110, or 205/80/16 for the 90 as an option from the factory when they were launched. Whilst not recommended the largest I would go is 235/85/16 which is more or less the equivalent of the 7.50, but wider
Post #976462 2nd Jan 2023 10:13pm
m33ufo
Wales
Thanks for your reply.
To confuse things just a little....they’re actually on a W461 G Class Wolf. As you correctly noted, the wheel currently has 7.50 x 16 Michelin XZL’s fitted. Have to say, the size confuses me a little because there’s no mention of the aspect ratio? I’ll assume it’s 80.
My tyre preference doesn’t have the option of an 80 section, I believe the closest for both is 235/85x16, so I guess it’ll be very marginally taller.
Thanks 👍🏻 110 DCPU
Mark
Post #976467 2nd Jan 2023 10:44pm
ossrider
United Kingdom 2010 Defender 110 Puma 2.4 HT Tamar Blue
My understanding:
7.50 x 16 are 7.5 inches wide and 7.5 inches in depth so the ration would be 100%.
235/85 x 16 are 235mm wide = 9.2 inches, but 80% of 235mm deep = 7.4 inches.
Hence, wheel width ideally should be greater for the metric 235's compared to the imperial 7.5's despite similar overall diametre.
Post #976551 3rd Jan 2023 2:44pm
m33ufo
Wales
Okay, that makes sense. Just one point, the 235 has a 85% aspect ratio so it'll be just over 7.8 inches tall. I can cope with an extra third of an inch Thumbs Up
The 235/85 16's sound like a good option. 110 DCPU
Mark
Post #976556 3rd Jan 2023 3:04pm
ossrider
Ah yes, of course it's 85% not 80% Embarassed
Glad you can handle the extra vertigo that may create Laughing
Post #976644 4th Jan 2023 12:38pm
TexasRover
I thought that 7.50 x 16 (or similar 'old school sizing') ALWAYS have an aspect ratio of 85, which would make 85 the 'mother' of the aspect ratio.
An aspect ratio of 100 would make for an excessively tall tire.
So the 'modern' equivalent of the 7.50x16 would be the 225/85R16, but mainly because the 7.50x16 tire is wider than 7.50 inch, which I think has to do with the difference between measuring the width on the thread or wall.
http://www.red90.ca/rovers/britishtires.html
Frankly it is a bit of a mess the this whole measurement.
Post #976661 4th Jan 2023 1:23pm
m33ufo
Wales
Thanks for your input, appreciated.
Looking at your chart via the link, the equivalent metric size is a 210/95x16 and the closest metric option is a 235/85x16.
So all good, 235/85x16 is the size Thumbs Up 110 DCPU
Mark
Post #976669 4th Jan 2023 2:31pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Largest tyre I can fit onto a 5.5 x 16 steel wheel?
m33ufo wrote:
Hello All.
Cheers Thumbs Up
I bought myself 5 nice BFG km3 7.50R16 for my 5.5J16
50K miles in 4 years and still 40% left (110CSW with furniture + roof tent)
In thé first months km3 tyres are quite stinky.
Then stinking stops and the houling sound starts when driving on the road...
Post #977474 10th Jan 2023 9:05pm
Chicken Drumstick
A good 7.50 x 16 should be about 31" tall. 16+7.50+7.50 (being rim, sidewall, sidewall).
Post #979297 23rd Jan 2023 1:43am
Chicken Drumstick
A 235/85R16 is too wide, if you look at tyre makers recommended rim sizes they will say minimum of a 6" wide rim for this tyre.
Of course you can make it fit, but technically it wouldn't be roadworthy in the UK if you were in an accident.
Post #979298 23rd Jan 2023 1:46am
Chicken Drumstick
Thanks 👍🏻
There are not many 7.50 x 16 tyres available at the moment. You might find XZL's still, which are ok. But not great and some remoulds. The remoulds are not always the correct size, some are too fat and some too short. But some are ok. Although most are either ancient tread patterns or more extreme MT's.
I think BFG KM3 MTs can be had in a 7.50 x 16 and there are a couple of other makes, but you'll really have to search for them.
Another option is to get some wider rims and run a 235/85R16. The 130 rims are 6" wide as are Wolf rims or replica Wolf rims. Quite a lot of choice really.
Post #979299 23rd Jan 2023 1:49am
