![]() | Home > Td5 > Broken ignition barrel |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 ![]() ![]() ![]() |
get a new ign lock and barrell they not expensive!
It is also a good time to replace your two door locks at the same time as they probably do not work as well as they should do
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
So not worth trying to repair. I’ve managed to find a genuine one on eBay for £85 as opposed to circa £130 (bought in error by the seller), so you’re right…not worth trying to repair.
I just wondered if it might have been something simple like a self tapper having dropped out that I wouldn’t be able to see until I removed the barrel. But if they are not with faffing with or unable to be repaired then decision made. Thanks chaps 2002 110 td5 |
