Home > Maintenance & Modifications > Front Door captive nuts - Land Rover, Bearmach or ??
Page 3 of 3 <123
I too have had good buying experiences from that seller, he/she/they is/are on my "reliable" list.
Post #976248 1st Jan 2023 10:28am
nitram17
Baytown wrote:
Censored , I just lost two captive nuts inside the Sil on my Rt side drivers door while attempting to fit new Optimil hinges all around on my 110.
I can’t find any in stock in Australia which would be delivered fast (ish) as it’s now 1 Jan 23, so I found them easily available via UK eBay.
I bought 8 of these and they are at the UK airport now after 2 days, so excellent service from this seller over Christmas. You would be very hard pressed to get such good Aussie service or
from the Post Office.
I recommend the seller.
All the best for the New Year everyone.
Ken
Could you not have retrieved them with a flexi magnetic grabber?i know i have in the past!
Post #976256 1st Jan 2023 12:27pm
Dinnu
Used a strong neodymium magnet (have several to modify drain plugs for diffs etc) through the opening for the lower hinge when I dropped a nut plate on mine.
Be careful when installing the nut plates. Mine were a bit hard to slide, and managed to get the screwdriver I was pushing them with to slip and gouge the paintwork Banging Head 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #976279 1st Jan 2023 3:47pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Could you not have retrieved them with a flexi magnetic grabber?i know i have in the past![/quote]
I live rurally, and don’t have a flexible magnet pickup; I have not seen one before. I only have a telescoping type which didn’t fit into the panel. I also tried my flexible claw pickup but that was no use. I’ll go to eBay and look for a flexible magnet pickup now actually, it sounds like a good piece of gear.
Post #976311 1st Jan 2023 8:18pm
nitram17
this would have done the job.
https://www.ebay.co.uk/itm/403008700902
Post #976332 1st Jan 2023 11:41pm
Baytown
This is what I’ve just purchased from eBay vs driving 200kms to try to find one.
 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #976333 1st Jan 2023 11:54pm
Baytown
So I thought I’d concentrate on the mid doors. 🤬 Even worse, the right lower hinge nuts (? a welded nut bar?) has fallen into the centre door pillar, and I’m stuffed if I can see anywhere to access the back of the pillar to retrieve or fit new units. It won’t take captive nuts that can be fitted from the front or side of the pillar. It’s got me stumped, and of course, any vids on YouTube etc only discuss 90s.
Any ideas with this at all? (Note lower mid door hinge.)
Post #976336 2nd Jan 2023 6:34am
Dinnu
Did you check the in side? B posts have large openings on the inner side for the nut plates to fit.
PS. Great looking 110 there Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #976337 2nd Jan 2023 6:50am
Baytown
Hi mate;
Yes, I checked the mid height internal cut out. I can’t access low enough via this due to it being blocked. There was no ability to access the area in line with the lower hinge bolts. I’m sure this was the case but not sure what was stopping full access. If it’s not the shape of the pillar, but now you’ve got me questioning myself!
I’ll go out in the morning and check again Re the mid height cut out access, and thanks for the compliment. I do love my 6.2 LS3 powered 110.😉 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #976345 2nd Jan 2023 8:25am
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
The bottom set of door hinge bolts are accessed through the gap between the 2nd row kick panel and the back of the battery box underneath the vehicle, open to the elements. Get on your back and look up and you'll see the point. They can often drop right out, or get caught at an angle.
The mid height access point only serves the top set of bolts.
HTH
Dunc North Cumbria Search and Rescue - Team Leader
Post #976362 2nd Jan 2023 11:38am
Baytown
Thank you Duncan.
I’ll get under the vehicle and look this morning, but I’ve Sil fuel tanks fitted so I wonder if that’s why no nuts have dropped out. I bet that’s an issue now!
I really appreciate your guidance with this. 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #976448 2nd Jan 2023 8:37pm
Baytown
Duncan you legend!!!
Thank you Duncan, you were spot on.😉
The problem with my vehicle is that I’ve had to drop the right 65 litre Sil fuel tank to be able to access the cut out. As expected, the captive nut bar had dropped down. After a lot of mucking around, I’ve got the hinge bolts to fit into the captive nuts and tightened/allingned the door, so at least the original issue is all sorted. I expect I’ll need to do the same on the left side as well.🥺
Im really happy with the Optimil hinges though, they’re a work of art compared to the factory units.👍
Post #976479 3rd Jan 2023 3:23am
Baytown
Safest way to prevent captive nut bar from falling
After a tip from ‘Tombie’ in the Australian based group, I made a tool to prevent the captive nut bar from moving away from the bulkhead, and it worked a treat for the remaking mid door.
Cut the head off a longer suitable size bolt. I notched it so I could use it like a screw, and slip the old hinge over it, and new one onto it. Worked perfectly and no more dropping fuel tanks to recover the bar, and I hope this helps others.
Ken
Post #976809 5th Jan 2023 6:52pm
Page 3 of 3 <123
