- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
rallysteve
If you remove the front plastic grille you should be able to get something up to the underside of the latch to operate it. There is just a small lever which the cable attaches to. Presumably the cable has snapped near the latch but if not you can access the cable through the top RH wing panel.
Steve 02' 110 TD5 Double Cab Rebuild Thread
1st Jan 2023 4:03pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
