Home > Puma (Tdci) > Low power in 6th gear
Page 2 of 2 <12
happycar
Netherlands 2007 Defender 130 Puma 2.4 HCPU Java Black
Hi,
My defender td4 puma has a similar problem. Good power and rev pick up in gear 1 to 5. Changing gear from 5 to 6 the rev drop from 3000 rpm to 2000 rpm and stay there. It takes forever to rev. up. to 2500 rpm.
Feels like the car almost stops changing from 5 to 6.
All this happened after the engine was rebuilt, new vgt turbo installed and new remap (BAS remap, BAS hybrid turbo).
MAF, MAP, all sensor are good. BAS and my mechanic don't have an explanation. Spent over 15K for the engine rebuilt and end up with a car that's dangerous to drive on the motorway.
Does anyone have what could be the cause of this or have a solution to this problem.
Post #975765 26th Dec 2022 4:48pm
nicolas0505
France
my defender puma 90 2.4 does the same in 6th gear when I press the accelerator pedal below 2000 it's as if I'm accelerating in a vacuum. but I think I have found the problem it is a lack of fuel tank clogged for the moment I have sent injector cleaner, antibacterial water dispersant several times, I have an improvement but not completely I must still have dirt in the tank I also changed the fuel filter several times but the best would be to drop the tank to clean it
Post #976259 1st Jan 2023 12:36pm
Failing VCV does this. TheThunder Rolls🇬🇧🇺🇸
Post #976324 1st Jan 2023 9:51pm
JakkalsOO
South Africa 2003 Defender 110 Td5 DCPU Caledonian Blue
Has any one been able to resolve the low power in 6th gear issue?
I have replaced the VCV valve and no improvement.
Post #985644 15th Mar 2023 3:20pm
ScottieG71
Canada 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
I read in another forum not to run RPMS less than 1800...i will try to find the article...
Post #985672 15th Mar 2023 8:01pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Have you checked your hoses for splits? Sounds like it could possibly be a split in the hose to your turbo?
Jim
Post #985676 15th Mar 2023 8:25pm
JakkalsOO
Thank you for the replies.
I have checked the hoses, have done a pressure test on the boost system, while the engine is off.
It doesn't have any leaks.
When I drive the vehicle, it performs well, until I go up an uphill, then it looses power and then when
one feathers the throttle it increases the performance again.
When running diagnostics I can see that when this occurs the fuel rail pressure drops to +-1200bar from +-1600bar.
Post #985680 15th Mar 2023 8:52pm
My 2.4 Puma pulls like the proverbial train from about 1100 rpm, and pulls well in all gears including 6th. It has an early (c.2010) BAS remap, from the days before Pete offered two power options, and it was pretty feeble before this. The map's been on for 13 years and over 210k miles.
I don't think I've ever revved the engine over 3k and I'm not sure I'd want to.
Post #985812 16th Mar 2023 6:24pm
Why on earth would anyone want to do this?
Post #985813 16th Mar 2023 6:25pm
Page 2 of 2 <12
