Home > Puma (Tdci) > Advice on painting dummy vents hinge
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
Can anyone tell me if these hinges are easy to remove.
If so are these the screws holding them on.
Thanks.
Post #975758 26th Dec 2022 2:43pm
Dinnu
Yes, those are the ones. More information on LRWorkshop https://www.lrworkshop.com/diagrams/land-r...n_44901#16 for part number of gaskets, although I see forum members also cut some neoprene gaskets themselves. It is important to ensure a watertight seal around the bolts, else water will seep into the bulkhead, and corrode it from the inside out. I have used the OEM gaskets with a dab of glass sealant. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #975760 26th Dec 2022 3:26pm
Balvaig
If you are just refurbishing or replacing the blocks then do one side at a time and be careful not to disturb the windscreen frame by slamming the door or moving the vehicle.
There is a slight possibility that the windscreen frame might move, making the replacement of the bolts difficult.
Having replaced my blocks several times due to corrosion, I have found the original gaskets, which look like waxed cardboard, much better than rubber type gaskets which spread out beyond the blocks when tightening.
I refilled mine with copious amounts of Dinitrol sprayed into the holes, onto the blocks and gasket.
Post #975762 26th Dec 2022 3:54pm
Crofter
Thanks for the answers, I was hoping to paint these bits myself. There is quite a bit off painting needed.
Knowing which the fixings and potential pit falls like the windscreen moving was great.
Sunny
Dinnu and Balvaig thanks.
Post #975764 26th Dec 2022 4:18pm
Dinnu
Have removed a few windscreen frames and always found that the frame 'stuck' to the foam seal. Of course it is safer to do one by one, but then painting takes twice as long.
Just re painted the bulkhead and the window blocks, both off the vehicle at the same time, had no issues.
Alternatively find a good uncorroded pair, paint those, and replace one by one if you are not comfortable taking both out at the same time.
Unfortunately, with corrosion on aluminum, once it sets in, it is very difficult to clean and paint and not having the corrosion come back a short time later. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #975766 26th Dec 2022 5:01pm
Balvaig
A nice easy DIY job to paint them yourself. I bought a replacement set of original blocks for about £15 each, and sprayed them using rattle cans. I then refurbished the originals as spares.
For me, this meant the blocks were only off the vehicle for a short while. The windscreen surround was corrosion free and didn’t need painting.
A couple of photos are in my gallery.
Post #975767 26th Dec 2022 5:06pm
There's some detail of how I did mine here:
https://www.defender2.net/forum/post784740.html#784740
 Darren
Post #975792 27th Dec 2022 12:20pm
nitram17
Sunny
The original blocks are not painted on the bottom surface..so the moisture can get under the paint and corrosion starts at the bottom edge of the paint and works its way up...the bimetallic corrosion requires moisture to work.the window blocks are a small bridging sacrificial anode between the ali windscreen frame and the steel bulkhead,Make sure the blocks are painted fully ,use a paper gasket saturated in grease and they should be free from corrosion for the life of the car .also do one side at a time .Basically prevent the moisture you will prevent the corrosion.
Post #975816 27th Dec 2022 5:47pm
Crofter
Thanks for that info about corrosion, I will paint the bottom and get a suitable gasket.
Post #975818 27th Dec 2022 5:54pm
