Home > For Sale & Wanted > [Wanted] Puma High/Low Selector Rod |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2296 |
Evening all
I am after a Puma high/low selector rod if anybody has one knocking about? The rod with ball joints either end - pictured below circled red If you have anything let me know. Thanks > 110 XS Double Cab |
20th Dec 2022 5:08pm |
Pleeeaaase > 110 XS Double Cab
21st Dec 2022 3:31pm |
Yeah I think the balls are 10mm so if worst comes to the worst I can make up an adjustable rod with ball socket ends. I would rather the real deal though... > 110 XS Double Cab
21st Dec 2022 4:10pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17364 |
At over £220 the genuine part is disturbingly expensive for a piece of old tat! No surprise there.
How about a couple of these (or similar equivalents) with a length of threaded rod? https://www.cromwell.co.uk/shop/bearings-a...UN6792806K Similar items available from Amazon: https://www.amazon.co.uk/KJBGS-Bearing-Con...80242?th=1 |
28th Dec 2022 10:49am |
For info I have just measured the balls on a spare gearbox and selector tower and can confirm that the balls are 10mm diameter. It's relatively easy to find DIN 71805 ball sockets for 10mm balls, which would mean that making up a replacement linkage should be straightforward (and cost a lot less than £220). |
30th Dec 2022 1:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I've got loads of gas struts at work from old fruit machines. I can measure the ball on Tuesday if they're 10mm then can chop the "ram" off of one of the struts. one end is pre threaded so you'd just need to cut a thread on the other end and screw on the ball clamp bit (got plenty of those too)
30th Dec 2022 2:19pm |
