![]() | Home > Puma (Tdci) > Puma rear window latches |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3532 ![]() ![]() ![]() |
There is a rubber gasket between the glass and the external aluminium block. That tends to stick. Need to gently pry it off. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 391 ![]() ![]() ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2255 ![]() ![]() |
You can use a hair dryer to warm it up a little, it will soften the gasket and ease removal.
