Home > Technical > Heated windscreen help
G-P
United Kingdom 2006 Defender 90 Td5 CSW Zermatt Silver
Can anyone help me with the wiring on my heated windscreen kit?
I have a Positive and Negative wires that need fitting and 3 options on the relays and unsure where they should go.
Attached is a photo of where the 3 options are.
Hopefully that makes sense.
Thanks.
Post #975267 20th Dec 2022 4:00pm
Martin
Site Admin
Negative to a good ground point on the bulkhead.
Can't tell from the relays view where the positive to the screen should run, but likely to be on the left hand side, probably the bottom hole. But cannot be sure without seeing what relays/timers have been supplied.
Can you not contact the company who sold you the wiring kit, as this wiring is specific to them?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #975287 20th Dec 2022 5:36pm
G-P
Thanks for you help, I will have another play today.
Waiting on a wiring diagram from the supplier.
Here are some more photos if that helps.
Post #975352 21st Dec 2022 10:38am
Martin
Site Admin
Excellent Thumbs Up
The orange unit is the timer relay, the black relay is used to convert the negative pulse from the factory switch into a positive pulse for the timer.
Where do the red and orange/red wires go at the moment?
The long yellow is for an ignition feed
The long green (not the loop) is for the trigger from the switch  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #975354 21st Dec 2022 10:48am
