Home > Puma (Tdci) > Glow Plugs?
Page 2 of 2 <12
bodstruck
I recently replaced the manifold seals otherwise I would do at the same time. Shopping list:
Glow plugs £42
Inlet manifold seals (xCool £8
Manifold lower seal (the round one) £6.50
Post #975165 19th Dec 2022 7:00pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I changed the inlet seals as I was there but didn’t really need to. So I could have got away with just the glow plugs
Post #975172 19th Dec 2022 8:10pm
bodstruck
Job is now done. Ironically, it is mild now so it started very easily when I went to move it this morning Smile
They were all pretty tight but a bit of wiggling with a set of mole grips had them out easily enough.
Took a couple of hours but as ever, that also included time spent cleaning and also hunting for a replacement nut for one of the glow plug terminals that I managed to drop on the drive never to be seen again.
Time will tell if it cures the staring problem.
Post #975240 20th Dec 2022 12:43pm
bodstruck
Quick update after a bit more use. Starting is greatly improved, only needing a couple of cranks to fire up and the white smoke is no more.
Let's hope it stays this way if it cools down again Thumbs Up
Post #975796 27th Dec 2022 1:01pm
hornet
Do you guys measure resistance of the glow plugs before or do you change them on suspicion? Starting problems might have other reasons as well Wink
Post #976915 6th Jan 2023 3:18pm
bodstruck
I didn't but I know that others have done.
I did test them once they were out but I recon even if they did glow I would have changed them. Smile
Post #976924 6th Jan 2023 6:08pm
Page 2 of 2 <12
