Home > Puma (Tdci) > What are these cable tied white plastic blocks?
miker916
Scotland 2010 Defender 110 Puma 2.4 SW Alpine White
Anyone happen to know what these are? One fell off under the chassis when i was applying Lanoguard last week and noticed another this morning when i lifted the passenger footwell mat.
Post #974956 17th Dec 2022 10:04am
Dinnu
Those are cable tie bases and have a double sided tape backing. They are not used by Landrover and someone else have used them for something else. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #974958 17th Dec 2022 10:14am
They look like a cable tie mount that's usually fixed with a sticky pad on the underside. Darren
Post #974959 17th Dec 2022 10:15am
Ianh
The only mod I’ve seen them used for is to close the gap between the heater blower air intake and the supply ducting. You glue one either side of the blower intake, one either side of the ducting, then pull them together with cable ties.
https://www.defender2.net/forum/topic75787...eater+duct
However all that is done in the engine bay, so would not end up in the passenger footwell if became detached !
Maybe someone used it to secure wiring or wiring conduit to the chassis, I.e tow bar wiring , and the lanoguard broke the adhesion. So look for any sagging conduit or wiring in the vicinity above where you found it.
Post #974965 17th Dec 2022 11:46am
miker916
thanks for the replies at least i know its not factory, car is ex police/customs so who knows what additional wiring it had (still has the blue flashing lights front & rear but they aren't wired up)
Post #974985 17th Dec 2022 3:29pm
You might want to remove the blue lights, at least if they are visibly blue in colour when unlit, since it is illegal to have them fitted (anything which resembles a blue light, lit or unlit, is not allowed).
Either that or wire them up and use them to get to your destination quicker!
Post #974999 17th Dec 2022 5:26pm
