Home > General & Technical (L663) > Rear Camera View Changed |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2761 |
l can't see how software could alter what the camera can see, unless it's on a motorised platform !!
Have you checked the actual camera in question to see if it's correctly aligned/fitted? |
15th Dec 2022 7:31pm |
39Steps Member Since: 12 Dec 2020 Location: UK Posts: 48 |
Thanks for the reply. I tend to agree with it being a physical issue rather than software, LR have said the camera has been checked today and all is well. I have suggested is it worth switching the camera with one from another Defender to see if the problem still exists.
You can probably tell from my post I am a tad peeved with what I am being told by the dealer and to just accept it is what it is! They will not accept the issue happened following new camera modules and a windscreen replacement, to them it is just a coincidence. Maybe it is but then again... |
15th Dec 2022 7:42pm |
Can you compare the camera with another Defender, look carefully at it and see if the alignment is the same, it could be the lens looks okay but the camera module isn't seated properly in the housing behind.
15th Dec 2022 7:58pm |
Thanks again, I will suggest it to them when we speak again in the morning. They seem so set it is software and only LR can sort it (not the dealer) but hopefully tomorrow will be more productive.
15th Dec 2022 8:07pm |
Buz1500 Member Since: 07 Jul 2020 Location: Cumbria Posts: 150 |
I thought the rear view camera could be adjusted up & down and left to right by using the buttons on the mirror itself. It may only be by a small amount but it may just resolve your issue.
https://youtu.be/-DJ8tOLnNLY |
16th Dec 2022 7:59am |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 |
I think that's just for the rear view mirror as opposed to the reversing camera https://instagram.com/bentheoandrews
16th Dec 2022 9:47am |
Sorry, misread the initial post. Yes, I’m referring to the rear view mirror/camera and not the reversing camera. The caffeine obviously hadn’t woken me sufficiently when reading the post this morning.
16th Dec 2022 10:58am |
Thanks again for the replies. It would be great Buzz if the rear camera could be moved as that would easily solve the issue!
Update from the dealer, alignment is fine on the camera and they maintain every Defender they have has the same view other than the loan one I have here. They are going to switch the camera from the loan Defender onto mine. So from the updated info, the presumption is all of the Defenders on this forum should now have the same view where the bottom part of the rear spare is seen on the reversing camera, I am not sure if this is true?! Any suggestions as how to proceed with the dealers? Thanks for any help. |
16th Dec 2022 11:24am |
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 |
on my MY23 when reversing I see the bottom of the spare tire in the pivi screen. It has been that way since new.
16th Dec 2022 1:14pm |
Thanks Matt for the reply. From that I am presuming either it is a software update, or the camera on the newer models is different to the earlier ones. As the car had new camera's fitted, due to failure of the old ones, it looks like we have a newer style camera?
If it is software then everyone else's older models should be seeing the same view, no-one on the forum (currently) has responded to say they have seen a change. Your reply really helps, even though it probably is not what I want to hear If this is the new view from the rear camera, it is really annoying when for 2 years the view has been without seeing the spare. |
16th Dec 2022 1:23pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2635 |
According to the guy at JLR who fits the cameras at the factory, he says he can’t see the problem…
Click image to enlarge |
16th Dec 2022 1:29pm |
16th Dec 2022 1:31pm |
Here's a picture of how mine as looked since day 1
Click image to enlarge Last edited by MattF on 3rd Jan 2023 2:04pm. Edited 1 time in total |
16th Dec 2022 6:24pm |
Click image to enlarge Thanks Matt, that is how the camera view was on my car this is how it has looked for nearly 2 years and the loan Defender I currently has looks the same (the photo is actually from the loan car), however when the camera's were fixed the view changed to how yours is. So the questions remain, software or physical camera? Is there anyone on the forum who has noticed a change in their camera view recently, with a 2020/2021 110 please? If it is a software update, am I right in my presumption that everyone's view should change for the pre 2023 models? |
16th Dec 2022 6:35pm |
