[For Sale] Land Rover Defender 1999 TD5 Manual 2495 Rioja Re
Due to lack of use (covered under 100 miles since purchasing a year ago due to working away), I have decided to part with my 1999 Defender 90 TD5 in Rioja red. I thought I’d get more use of it than I do, but with 2 young kids, it’s just not practical compared to the daily driver.
It’s on 142k miles and has only got 2 previous owners; a company for the first 10 years of its life and an older gent for the later 10 years. Excellent service history with loads of invoices (40 + worth several thousand from tyres, to services, to UJ’s with all brake pipes and flexis replaced in Nov 20 & steering box replacement in June 1.
It failed its MOT in Oct 2021 and was PX’d with the garage replacing the rear 1/3rd of chassis along with some other repairs and undersea (liberally applied) and fresh MOT in Feb 2022.
Since purchasing in Feb, I have done everything its needed with no expense spared including:
• Replacement injector seals & injector wiring loom
• Rocker gasket
• Camshaft oil seals
• Turbo oil return pipe flange refaced and new seal
• Fuel pressure regulator replaced with genuine part
• Full service inc air/fuel/oil x 2 filters & all oils (inc diffs, gearbox, transfer box)
• Replacement ignition switch (was worn and felt sloppy) and 3x door locks with genuine parts – all keyed alike
• Central locking kit fitted and wired in to 10AS unit so works off factory key fobs (2x supplied)
• Stainless rear door sill and rubber seal
• LED lights fitted all round
• EGR delete kit fitted as recommended on all the forums
• LOF clutch spring and slickshift gear change kit fitted – totally transforms changing gear
• Plenty other smaller jobs i.e. fuel filter clasp replacements, bonnet catch replaced, door switches replaced etc etc (approx. £2k spent on parts!)
Bodywork could do with some attention as has the usual dents as pictured (photo included of the worst paint being drivers front wing) but, for a working 20+ year old car, it’s not too bad!
£10,950 with viewing available in Glasgow. Will be for sale until early Jan and, if not sold, will tuck away in the garage for the year
Thanks,
Andy
13th Dec 2022 8:38pm
andyg0141
Price reduced to £10,950. Thanks
15th Dec 2022 11:39am
andyg0141
Have been asked a few times for pictures of the underside - some below.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
