Home > My Defender > 110 Puma to M57 and 8 speed auto
Page 6 of 9 <123456789>
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Re: Brakes
mata wrote:
These kits usually require 30mm wheel spacers so the calipers clear the back of the spokes but my Evocorse Dakar Zeros clear due to their zero offset. There's little space between the inner barrel and caliper though so 've moved the wheel weights from the inner rim to behind the spokes.
What a great build and amazing truck!
Cool to see this with the brakes. I always wanted a set of the big brakes for mine but never wanted to run spacers. Great to see they fit with 0 offset wheels. I may have to go for this in the future.
Wish i had this engine and gearbox in my 90 Thumbs Up
Post #973422 4th Dec 2022 10:39pm
Black Puma
United Kingdom 2011 Defender 90 Puma 2.4 SW Sumatra Black
What a great project. Love that steering wheel and the EVO Corse wheels are spot on. They were on the short list before I picked up Bowler 16"
Have a question about the LOF brakes. I have been advised regarding the bowler calipers and discs. If you change pads end of life you have to change discs as well, which is about 1700 quid. Is this the same with LOF, seems like a nice option if they fit behind my Bowler wheels.
Post #973449 5th Dec 2022 12:12pm
90 Dreamer
Why do you have to change discs??
In general terms pads and discs have little bearing on each other in terms of being 'matched' and as long as the remaining component is in good condition then it should make no difference??
Post #973528 5th Dec 2022 9:26pm
Black Puma
That's straight from Bowler to me over phone. Maybe incorrect?
Post #973585 6th Dec 2022 11:36am
90 Dreamer
I would want to know the exact reasoning....... there is no technical problem why it must be done unless they have some existing damage / wear
Post #973711 6th Dec 2022 9:56pm
nspr
Curious how much fab work did this swap actually involve? Eyeing up getting another landy after selling my TD5 a few years back; looking at MW's site, you could almost be mistaken for thinking this could be a buy, bolt and program jobbie? Surely not!
Post #974705 14th Dec 2022 11:26pm
kenzle8a
I think it depends on the chassis used, MW Machines do a Richards Chassis thats a bolt in for the mounts and Marsland do an adapter chassis with bolt holes in place for mounts that Mahker and a few others do. Diesel Pump UK do a kit for the 200tdi chassis to use the OM606 as well.
Post #974721 15th Dec 2022 9:24am
Cardinal
https://lofclutches.com/blog/product-news/...-110-dcpu/
I thought this was a useful summary of what is involved
Post #974733 15th Dec 2022 11:13am
Black Puma
It's just what they told me. Appreciate your questions dreamer, but I don't want to derail the OP talking about Bowler.
My main question was to mata or any one with experience with the LOF system. But I am guessing that no need to change disks with LOF when pads expire, and I will chat with the chaps at LOF.
Mata how's the braking system feeling now are you happy?
Post #974968 17th Dec 2022 1:25pm
TSAF
Greece 2015 Defender 110 Puma 2.2 HT Venetian Red
Huge fan of M57 swaps
Post #977358 10th Jan 2023 2:17pm
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Not been here for a while hence the slow response.
Regarding the LOF 4-pot front kit i'd say its ok but not startligly different to new oem brakes. Tje main advantages are a thicker disc, slightly bigger pad area and a huge range of pad options. On my defender they feel like they take a bit more pedal pressure than they should, but this could be for many reasons.
The kit came with an organic 'street' pad which i used for a few months but felt like they were lacking initial cold bite. Id always liked the feel of forodo ds2500 pads on other road cars (even when cold) and for some reason thought i'd achieve this with EBC yellow pads so tried them. Unfortunatly this wasnt the case and the initial bite felt more dead so i eventually swapped back to the street pads.
I should probaby explore more pad compounds but as ever theres always a list of things to do. Currently trying to track down an annoying vibration so next up in the patrs cannon is a transfer box rebuild - it was opened pre conversion for a sleeved end case and during conversion for an lsd but everything else has 165k miles on it and its not having the easiest of lives. Front diffs probaby due a rebuild too.
Post #992446 13th May 2023 7:12am
Mo Murphy
Your thread has been an inspiration Mata 😁
Almost there ...
 The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #993219 18th May 2023 10:38pm
Co1
Nice work Mo!
Post #993228 19th May 2023 6:11am
Mo Murphy
Thanks Col. The Land Rover 90 - Many are called, few are chosen.
Post #993347 20th May 2023 12:10am
tommobot
mata wrote:
Not the one that destroys gearboxes, I’m now happily using a Turbo Lamik.
Can you give a bit more info on this please - Currently looking at 8hp setup vs 6hp.
House of Torque sell a CANTCU controller for the 8hp, the claims OEM style shifting.
Ofcourse, this sounds perfect, and looking at your videos it seems the shifting is perfect with these 3rd party controllers but I do question the longetivity of them...
I don't want to be dicking about with replacing gearboxes and controllers every couple of years, as that would be no better than where I am currently! Big Cry
Post #1003731 11th Aug 2023 10:12am
