![]() | Home > Puma (Tdci) > Dim dip headlight deactivation... |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Welcome to Defender2 Craig, this has been covered many times so do a search and find all you need
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
There are instructions here https://www.landroverexpedition.com/techni...dip-relay/
There are some pics of when I did it in my thread here https://www.defender2.net/forum/topic53240-156.html > 110 XS Double Cab |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5850 ![]() ![]() |
Yes easily disabled.
Get the pink relay out and bridge the large two terminals together on the relay holder with a suitable piece of wire with two terminals crimped on it. ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
An alternative and probably simpler method is to locate the dim-dip resistor under the front offside wing (midway between the radio aerial and the plastic panel on the wingtop) and unplug the connector from it. Job done.
Cam-Tech-Craig Member Since: 27 Nov 2022 Location: Cam Posts: 19 ![]() ![]() ![]() |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
I did this, but also bought a replacement plug set, bunged the ends up with Dum Dum then plugged them into the exiting plugs This way water is kept outbox the open terminals. |
Managed to buy a new relay on the bay of fleabags for £12...
An expensive solution!
