![]() | Home > Technical > TD5 Alternator Oil Return Pipe - SQC500010 |
Howdy folks. Weird one tonight. The oil return pipe on Miffy is wearing a fair amount and I suspect it need replacing.
The part number is SQC500010 (supersedes ERR6996) - Number 10 in the below image ![]() It's no longer available anywhere... ![]() It is only a pipe, but does anyone happen to know its internal diameter so I can buy the right size pipe, please????? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
10mm ID (3/8") and 17mm OD.
Just replaced mine using some oil delivery hose. Original hose clips still fitted fine, if a bit on the tight size. I do have plenty of offcut but I dont have any at home to send I am afraid. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Brilliant Gents. I knew someone would have done this
![]() No problem with the not being able to send you done more than enough Steve. ![]() Time to find some pipe ![]() |
No probs
![]() In case it helps, i bought ebay item: eBay Item No. 111569393001 Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks Steve.
![]() Parts are on their way, 50cm of hose and two Mikalor springs clips for £4.50. Be GONE weary leak.... ![]() |
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 100 ![]() ![]() ![]() |
Thanks for having picked this up and shared the ebay link
also out of curiosity, that OEM clamp used. what tool is used to open these up? they are a major pain to get off ... thought the Mikalor clamps are one kind but these were different all together Td5 110 Station |
Thanks... ![]() There is more in the Miffy thread, about halfway down the page - https://www.defender2.net/forum/topic53859...;start=285 The tool you need to undo those spring clips is either - https://www.amazon.co.uk/ACHANFLY-Ring-Typ...KQ2U81CV7O or https://www.amazon.co.uk/FAVENGO-Pliers-Fl...amp;sr=8-6 It is the same tool used for the cam cover breather pipe clips as well so well worth having in your toolbox. |
