Home > Tdi > 1999 300 TDI CSW Rear Speaker mounts
ryan_1993
United Kingdom 1999 Defender 90 300 Tdi CSW Rioja Red
Morning all,
Has anyone fitted the below MUD branded speaker surrounds into the rear?
Mine currently has a two aluminium colour coded shrouds covering the wiring for the break lights/indicators and the wiper and heated window, but they rattle quite badly very loosely fitted.
I was hoping these would probably rattle less and also give me the option of adding speakers into the rear in time. I do believe they are more for the Puma models so just wanted to know if these would fit properly?
Link to the item: https://www.mudstuff.co.uk/products/mud-rear-speaker-panel
Post #922306 22nd Sep 2021 7:32am
Mo Murphy
They look very nice Ryan and like all Mudstuff parts should be well made but it's a very expensive alternative to tightening some screws to stop the light covers rattling !
50 Shades of Pennine Grey
Post #922346 22nd Sep 2021 12:24pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
This is what I did.
Post #922348 22nd Sep 2021 12:28pm
ryan_1993
Mo
Yeah weird thing is there is only one screw going into into the wheel arch section securing them. I’ve removed both metal covers and there’s literally no extra screw holes or anything drilled into the body work to help secure it.
If I drilled I’d be worried it would just come through the other side and then be visible externally even using very short screws as the aluminium is only very thin.
Post #922350 22nd Sep 2021 12:54pm
ryan_1993
jfh wrote:
This is what I did.
Arrow
That’s very nice where did you buy the kit from?
Post #922355 22nd Sep 2021 1:16pm
jfh
Thanks.
I didn't think the MUD ones was practical for me and there wasn't really anything else so I made them myself.
Post #922357 22nd Sep 2021 1:19pm
donmacn
FWIW, what I did initially, and it lasted for many years, was to mount medium-ish pod speakers to the roof lining itself.
This is what I had - or very similar
I used a strong piece of fibreboard or plastic card on the back of the roof lining to spread the load of the speakers. They were right in the back corners where the lining is reasonably well supported. I think this is a good place to put speakers because how often do you use that very space, right up in the back of the roof?
If I'd kept that arrangement, I had plans to put some sort of reinforcing strip, behind the roof lining, from gutter to gutter, and mount the speakers to that. In the end I've gone for something different, but that set of speakers was up there for easily 10 / 15 years. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #922359 22nd Sep 2021 1:44pm
Dinnu
I have fitted a pair of those MUD speaker panels on a family Defender. It was a bit of a pain to fit the one on the driver side due to the fuel filler intrusion, but would not be an issue on a 300tdi.
Quality wise they are very good, plastic is strong too.
IIRC, the aluminum covers have 2 self tapping screws into the wheel arch (they will not be visible from outside). On older vehicles, at the top, they kind of slot in one of the pop rivets that fixes the vertical corner capping. On newer Defenders there is an M4 (or M5) screw.
But you can fix the rattle by a bit of 2mm foam double sided tape. Easy to pull off and replace in case you need to access the wiring, which hopefully not needed often, as bulbs can be replaced from outside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #922380 22nd Sep 2021 4:04pm
Andyju
I have fitted the Mud speaker panels to my 1998 110 CSW. The edges needed trimming with my dremel to make them fit but once trimmed they fit fine. I also fitted a 12v socket into one of them 1998 300tdi 110CSW
Freelander 2
Various D1 and D2s gone to the big crusher in the sky
Post #924111 2nd Oct 2021 7:41pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I’ve got high levels fitted too - probably could do with a little more support, but definitely a great location.
I’ve got an additional fastener on my ali covers which fastens from outside. An absolute tragic task to do on the O/S courtesy of the door 😂
Post #924807 7th Oct 2021 7:27am
MattH268
United Kingdom 2013 Defender 110 Puma 2.2 HCPU Fuji White
I fitted these mounts to my 90 a few weeks ago as I upgraded the speakers to a set of Focal PC130.
Really easy to fit but I did need to trim the nearside mount as it didn't quite have enough space for the wiring to go around/through it. The speakers I had were quite poor and I didn't fancy modifying the battered alloy speaker mounts I had plus the rear nearside speaker was sheltered by the storage chest I now have on the wheel arch. I liked that these mounts put the speakers closer to the door. They wedge in really tight and i haven't put any fixing in to secure them either. I don't know if this is because the window trims have all been replaced with later model trims or not so makes it tighter.
M
Post #935549 29th Dec 2021 5:03pm
sidewinder
Hi Matt,
Did the later.rear trims fit ok. I'm looking for rear trim for my 1989 but wasn't sure if they would fit as the small rear window surr look quite different.
Thanks
Stephen
Post #974009 9th Dec 2022 7:50am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Here is extract from parts book - there should be a bolt through the body work to hold them.
Post #974013 9th Dec 2022 8:16am
Retroanaconda
I fixed mine with self-adhesive Velcro strips. Very secure, no rattles and easily removable to access wiring with no leak paths to the outside.
Post #974014 9th Dec 2022 8:20am
MattH268
sidewinder wrote:
Hi Matt,
Thanks
Stephen
Hi Stephen,
They needed a fair bit of trimming, shaving and fettling for sure, time consuming but luckily for me the guy fitting them was a dab hand at modifying to perfection and the outcome is spot on. I think if he was to do it again though, these later trims would have been sold on and some originals ordered in and fitted.
The speaker trims I fitted and they slotted in very easily.
Matt 300tdi 90 CSW
2.2tdci 110 HCPU
1972 Series 3 88" Truck Cab
Post #974025 9th Dec 2022 9:51am
