![]() | Home > Maintenance & Modifications > anyone fitted the Extreme 1.5/2.5 Inch Lowered Springs |
calibrarwd Member Since: 27 Feb 2022 Location: belfast Posts: 11 ![]() ![]() |
![]() Click image to enlarge fitted a new set of extreme 4x4 - 2 in springs in my 90 xs 6 months ago and think they are brilliant Had a set of urban truck -2 in and they were terrible , far to stiff ,The extreme springs are a progressive spring and the ride is even better than on standard springs . couldn't rate them high enough |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 830 ![]() ![]() ![]() |
![]() Click image to enlarge Just enough clearence in my local car park. Authorities here will not allow me to fit springs without homologating them which costs money here Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 515 ![]() ![]() ![]() |
My 110 van sits at 80 inches tall, where its sat on a stone driveway. That's measured at the back, which is the highest point, and with minus 1 inch rear lowering springs. This is with slightly larger than standard 33 inch tyres, opposed to the standard 32's, which would have added about 1/2" to the height. This would also be lower in a station wagon as they're a bit heavier, so pretty close.
The 2m height may well have some leeway too. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
Or go for Air Suspension.... gets you down to about 190cm in access mode.
Feel free to PM me. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
mattburke88 Member Since: 25 Nov 2021 Location: MK45 Posts: 7 ![]() ![]() ![]() |
@London_Landy have you fitted the springs yet? Do you need new shocks or ARB? I have emailed Extreme 4x4 as after the same setup
@calibrarwd did you fit yours with new shocks and ARB? |
