Home > Td5 > 15p - replacement engine impact on ECU? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1630 |
injectors will need coding to the car if they are the same green or black tops. it will run though without coding. on a rebuild i wouldn't use unknown injectors but would swap them for a good set of refurb ones with warranty
5th Dec 2022 1:45pm |
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 100 |
Thanks for the insights - they should be both green ones given that the engine is also from a Defender 15p - unless the factory randomly selected the injectors during production.
I see the point with the refurb injectors (lrparts.net offers 5 refurbs for 1k pound) To understand it correctly: even the new refurbed ones will need coding? Guess that would require a LR specialist or access to the software at least .... Td5 110 Station |
5th Dec 2022 1:50pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 533 |
It will run on non coded injectors, mine has for years. Obviously it will run better coding them to the ECU, even refurbed ones will need coding.
5th Dec 2022 6:38pm |
