![]() | Home > Tdi > Fuel Gauge to Sender Wiring |
MattH268 Member Since: 01 Dec 2021 Location: Moray Posts: 66 ![]() ![]() ![]() |
VDO doc I found says this
Note: You must install so float ball is positioned to the sender body, when the float pivot is facing you. If you have found that your gauges reads backward after installation you have installed the float in backwards. To correct this you must disassemble and reposition the float. I've not looked at the current float yet but i'm not very optimistic that the float can be repositioned. 300tdi 90 CSW 2.2tdci 110 HCPU 1972 Series 3 88" Truck Cab |
