Home > Td5 > Central locking help!!
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Morning all! I recently purchased a 2003 90 which has the factory central locking, though the previous owner told me a mechanic of his disconnected it....He is unsure how it was disconnected though Laughing
with that in mind where should I be checking first? is there a wiring diagram for the central locking system? Would be good to have it working.
Thanks
Nick
Post #972796 29th Nov 2022 11:12am
Jackfirman98
I believe the immobiliser and 10AS is the controls system, maybe look for from wiring from that, and also inside the door panels towards the rear of the door if memory serves well
Post #972797 29th Nov 2022 11:15am
2hel
Well, I'm sort of assuming (hoping) its electrical and an easy fix Laughing
Post #972798 29th Nov 2022 11:17am
Jackfirman98
Not so sure about easy ahaha, I have mine to sort out yet 😝 If your immobiliser is disabled that I believe disables them too
Post #972799 29th Nov 2022 11:18am
2hel
well im totally new to defender life so if anyone can help me with things to check and where to find them it would be appreciated
Post #972800 29th Nov 2022 11:21am
Jackfirman98
10AS (alarm system control) should be behind the dashboard, Google if it you'd like to know how it looks 😁 Looks kind of like a rectangular can
Post #972803 29th Nov 2022 11:28am
Jackfirman98
By behind dash, I mean speedo console πŸ€”
Post #972804 29th Nov 2022 11:29am
2hel
Thank you ill check that first!
Post #972805 29th Nov 2022 11:35am
ibexman
Isn’t it controlled via nanocom πŸ€”
Post #972811 29th Nov 2022 12:03pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Plug in a Nanocom and select 10AS immob. See if it is disabled. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #972812 29th Nov 2022 12:19pm
Jackfirman98
In theory shouldn't the dashboard blink? And also the key for work?
Post #972813 29th Nov 2022 12:22pm
landy andy
An easy place to disconnect the CL would be the actuator in the drivers door. That way other parts of the security system still work.
Post #972822 29th Nov 2022 1:36pm
