Home > Technical > Removing steering shaft on TD5 |
Tr90 Member Since: 06 Jan 2020 Location: Essex Posts: 135 |
Glad you got it sorted.
27th Nov 2022 8:40pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1777 |
When I did the steering box on my 100" Bitsa, I put a strap around the box and got my (then) 11 year old daughter to hold the box from the top whilst I positioned it from underneath - I told her it was strength training for her black belt!
Keith |
27th Nov 2022 8:50pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I had replaced once single handed. I used some wooden wedge between the chassis and the box to support its weight until I aligned and got the first bolt on. Than it was just a matter of levering from the drop arm to align the next bolts. Cant remember if I used a strap or used one of the hydraulic connections to prevent the box from falling over.
More recently I re installed the box, but not having the mudguard in the way made the job so easy. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
28th Nov 2022 6:39am |
