Home > Technical > Removing steering shaft on TD5 |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
Have you removed the steering box
27th Nov 2022 10:57am |
jamesthebaker Member Since: 17 Oct 2022 Location: Brittany Posts: 32 |
No because I would need to uncouple the shaft to the steering box first
27th Nov 2022 11:00am |
Tr90 Member Since: 06 Jan 2020 Location: Essex Posts: 135 |
Hi.
I have just replaced my steering box on my 2000 td5. It looks like I have a slightly different shaft to you. However. I didn't take the shaft off. I undid the pinch bolts holding the shaft on to the splines of the upper steering column and the shaft from the steering box. Not the ones holding the UJ to the shaft. After applying a little lubricant I found that I could tap the shaft upwards and it came free of the steering box. To be fair the removal and refitting of the box was harder than I thought due to the weight of it and trying to line everything up. TOP TIP - mark the shaft and the steering box spline so you will know where to rejoin once its is back in place. I found this video very helpful -https://www.youtube.com/watch?v=S0JC5ZdU8U0 |
27th Nov 2022 11:11am |
Thanks for your answer
I'm trying to follow the video you sent, which is very good Unfortunately I'm not able to remove a single bolt holding the shaft to the splines. I guess they're rusty and I have no clue of how to remove them as lubricant and little heating don't help. |
27th Nov 2022 11:25am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
You have no alternative, you have to be able to loosen at least two of the (male) Torx head screws. There is no other was to remove the steering shaft or box.
Even if you were to cut the shaft to remove the box, you'd still have to remove the remains. |
27th Nov 2022 11:37am |
Yes that's what I was afraid of.
Any tips that I may not have thought of to manage to unscrew these bolts ? |
27th Nov 2022 11:39am |
Other question, do you think the servo brake can handle a lot of heat ? Can I keep on trying to use the torch below it ?
27th Nov 2022 11:45am |
Make sure that you are using the correct socket or wrench and use the longest handle you can. You may be able, by positioning the steering carefully, to use an impact wrench. I'd be wary of heat due to the proximity of the servo, steering box, and other heat-sensitive components.
27th Nov 2022 1:39pm |
Plenty of lubricant and the right size socket and extension bar. Wouldn’t use heat. Impact wrench is a good call.
Just a heads up. You really should get some assistance fitting the steering box back in place. It is not easy holding it up with one hand and trying to fit the bolts back. |
27th Nov 2022 1:53pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
As suggested above, and if you manage to rotate it slightly, do not keep undoing, but rotate back and forth and undo a little bit more and repeat with the back and forth motion. This lets the lubricant in and the rust out of the threads.
Also ensure that the protruding threads are clean, but I think they are according to one of the pics. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
27th Nov 2022 2:12pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1804 |
Once the bolts are loosened, if I remember correctly, the flat section of the shaft doesn't continue to the end, so it is necessary to take the bolts out completely to remove the shaft - I also loosened each side of each of the UJ's as it gave a little more travel to move the shaft away.
HTH Keith |
27th Nov 2022 2:44pm |
^^ Indeed, and this makes it a complete pain if one of the bolts shears off!
27th Nov 2022 3:08pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 733 |
WD 40 is not a penetrating oil, just a water dispersant. A proper penetrating oil/ lubricant should help.
Good luck, sounds like a b of a job. |
27th Nov 2022 3:22pm |
If you don't have any proper penetrating oil (such as Plus-Gas) use diesel fuel, it's surprisingly effective and much better than WD40 as a penetrant.
27th Nov 2022 3:57pm |
