Home > Faults & Fixes (L663) > D250 Holding onto gears |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 266 |
I don't think it's an issue but intentional. Mine does the same.
It holds onto the gears for engine braking, so you don't cook your brakes. Your engine might sound strained but it's ok as long as temps and oils are fine. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
25th Nov 2022 7:04am |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1404 |
Ok, thanks for that. Bath is very hilly but its the only auto I've had that does it.
I'll keep persevering, but I'm still preferring my XC90 at the moment, which has been faultless with great dealer service. I can't say the same about Lookers. |
25th Nov 2022 8:22am |
Oswiperus Member Since: 12 Aug 2020 Location: Chelmsford Posts: 48 |
Just come back from a week in the Yorkshire Dales and found it was ideal the hilly bits. On the D4 I would have to use the paddles to keep a gear low enough for engine braking on occasion but the Defender was more effective at doing it itself without any intervention from me.
Just occasionally I would pop it up a gear on a longish medium descent when it needed it. 110 D300 SE Tasman blue |
25th Nov 2022 2:57pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
Funnily enough on holiday in Yorkshire and came down Sutton Bank which is a 1 in 4, today. Car automatically dropped its gears and came down at higher revs in low gear. Didn’t have to do anything. Don’t know if it’s reading the road signs or using the navigation to sort itself out but it worked. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
25th Nov 2022 4:27pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3411 |
I’ve noticed this with my D250, my 90 D200, if I’m being honest felt more refined. 24MY 90 D250 HSE, Tasman Blue
25th Nov 2022 6:21pm |
Ok, must be me. Thanks chaps.
26th Nov 2022 10:19am |
