Home > In Car Electronics > Interference to radio |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
All I can think of is EMF, so you can use some foil or shielding wrap where you can.
High current motors, LED lighting in particular headlights or LED light bars can all cause interference and USB power sources. All that can be done is use quality aerial / antenna cables, shield it all all and make sure you have good grounds that you have done. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
23rd Nov 2022 9:19pm |
Arnoldsally Member Since: 30 Oct 2019 Location: Derby Posts: 8 |
Thank you custom90steve, tried it all and I have no LEDs as they are a known problem to ham equipment and they are not allowed in the house lol.
Most sites are saying fit a suppressor to big items like the alternator but getting to it is another thing. Patrick |
23rd Nov 2022 9:32pm |
Have you tried ferrite chokes? Alternator whine can be an issue, but realistically the only thing you can think about to do with that is change alternator.
I know what you mean with Alternators, they are often a pain to get near. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Nov 2022 9:08pm |
Ebay is fed up of sending me ferrite cores, the Defender is full of them. If the weather is ok I am going to pull a fuse to see if it stops the noise and then work thro all the others too.
24th Nov 2022 9:25pm |
Might be worth doing a continuity check on the Antenna cable, possible break internal or replace.
I agree with ferrites, I found Alu shielding was more effective. Antennas and reception can be the most annoying thing, the most annoying thing to me is having to gain access to it and the cable. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Nov 2022 10:57pm |
Just to say thank you for all the advice. I used ferrite core on everything but the the biggest interference was from the USB connector pushed into the fag lighter, cannot believe it but ferrites sorted that, thanks all. |
13th Feb 2023 8:20pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Those things are nasty - whilst it would be simple enough to use a 7805 linear regulator and a couple of capacitors to drop the 12ish/14.4V to 5V for the USB instead most use a cheap switched-mode DC/DC converter to reduce the current drain whilst the engine is off. These produce a ton of RF hash due to their poor suppression - hence the need for aftermarket ferrites. |
14th Feb 2023 4:35pm |
Thank you Intercept, they are dirty and my ham radio equipment was suffering badly with them.
14th Feb 2023 10:09pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1231 |
When you say 50% is missing what on earth do you mean? Have you done something as basic as test the match on the aerial to your base unit? If the antenna match is off then no point in trying to chase anything else first. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
15th Feb 2023 8:10am |
