Home > In Car Electronics > Puma immobiliser |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
The starter relay activation coil gets +12v from the starter switch and the gnd is provided by the ECM so that the immobilizer can inhibit cranking and also (I think) so that cranking is inhibited when the engine is running.
If you can bridge The receptacles for pins 30 and 87 of the starter relay.with a suitable switch you can check if you then get reliable cranking, it will be independent of both ignition switch and ECM. The engine won't start without the ignition on and the immobilizer deactivated but should crank. |
20th Nov 2022 3:01pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
Yes I can get a crank if I bring 12v to 87 onthe relay.
I've just gone through and tested all the fuses under the steering wheel and don't seem to have voltage to quite a few of the fuses.. Back to the wiring diagrams I think! Just to confirm, I've checked the fuses under the seat too.. All ok. |
20th Nov 2022 3:07pm |
Interestingly, I've found ~6v going to pin 12 on the grey conector to the AS10.
This should be around 12v as its labeled "Battery Voltage". Not sure where this is fed from currently.. Wiring diagrams say Fuse 7, which on the fuse box layouts say isn't used.. The mystery continues.. |
21st Nov 2022 4:54pm |
Well I think I have sorted the issue. Within the AS10 there was a tiny bit of corrosion/staining on the green plugs pins that just happened to be on pin 10 (crank output).
Unit was removed, cleaned with IPA and a toothbrush and all traces of staining removed. For good measure I also resoldered/reflowed the connections for that plug as I've had that issue before with a very unreliable Volvo. All back in and the result is... A start!! Unfortunately it only managed 2 starts before the battery was exhausted. So its on the trickle charger and hopefully starts ok tomorrow! I, on the other hand, am tired, wet and questioning Land Rover ownership. |
21st Nov 2022 8:25pm |
