Home > Maintenance & Modifications > Open hole !!!! |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Look for wading plug locations for your vehicle. Find out the thread size as you may be able to find suitable ones at a plumbers merchant but if not I am sure they will be available via ebay etc
Alternatively pick some up from a land rover parts stockists (not landrover!). Last edited by Mossberg on 19th Nov 2022 3:13pm. Edited 1 time in total |
19th Nov 2022 2:56pm |
Poulstonb Member Since: 30 Jun 2022 Location: Styal Posts: 88 |
Found a radiator valve that fits !!!
Should it normally be open and just put something in it when wading ? |
19th Nov 2022 3:02pm |
I believe only when wading so don't fit them when not needed!
19th Nov 2022 3:15pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Normally always fitted on a TD5
Steve 02' 110 TD5 Double Cab Rebuild Thread |
19th Nov 2022 3:58pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 |
On TD5-era vehicles the plug is normally fitted…
…but if you look carefully at the photo you can see a little oblong drain slot right next to it, so it doesn’t really matter if you fit the plug or not. Yet another another weird Land Rover mystery! Dave Green Goddess - 1998 Defender 110 300tdi |
19th Nov 2022 6:21pm |
Oops! As I have a 300tdi I presumed they were similar so my apologies for giving the wrong information. I live and learn. |
20th Nov 2022 3:59am |
