Home > Td5 > Rear Doors |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 942 |
No not likely as “safari” doors had two parts with the tops being removable with sliding windows. These were available on Series I, II and III and the 110 Stage ones as well as few early 110s. Not very common at all. 🤷♂️ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
22nd Oct 2021 10:31pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 |
Try:
https://www.lrworkshop.com/ Create an account, add your VIN in the garage via menu, then search the door diagrams via the Body diagrams. This will bring up part numbers and seller links. |
23rd Oct 2021 7:01am |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1846 |
Depends what’s behind the question really.
If You’re looking for replacements, then as far as I know all the one piece doors are compatible from the “Defender” onwards. On my car (1994 Tdi) I have two Puma doors on the front; two ‘aftermarket’ on the second row; and aftermarket on the rear. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
23rd Oct 2021 8:41am |
Goldenballs Member Since: 22 Apr 2021 Location: Reading Posts: 64 |
Thanks all. I ended up buying one from Hairymonsterman on ebay. Yet to fit it but looks very sturdy.
22nd Nov 2021 12:21pm |
^^ Good choice. That's what I did in the end, and I've been very happy with it. No issues at all. Donald
22nd Nov 2021 5:15pm |
Finally got round to test fitting and getting it painted.
Can anyone recommend some replacement hinges & bolts? |
21st Apr 2022 10:18am |
defenderireland Member Since: 17 Nov 2022 Location: Kildare Posts: 3 |
Bearmach make a good set.
17th Nov 2022 11:04pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Bearmach dont exist any more! 02' 110 TD5 Double Cab Rebuild Thread
18th Nov 2022 6:27am |
