![]() | Home > Puma (Tdci) > throtle repsonce - while in low ratio |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
hi all
have read another thred that deals with a similar problem, but as i am not to sure if the other is dealing with throtle responce in low or high ration, i have posted this question. when i select low ratio, engage gears and start moving off, the engine tries to rev almost as if it is an antistall setup. if i accellerate, and then let off the throtle it stops doing it for a few seconds then starts again. this only happens in low ratio. it's a bit of a problem when trying to desend rocks as i was at the weekend, and trying to hold the car with the gears, caused a few hairy moments. anybody any ideas as to what this could be? i should point out, that i have had an auto box fitted. Cheers keith puer claudius Last edited by kljw on 14th Apr 2009 3:30pm. Edited 1 time in total |
Could be the auto box 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
The AC fan was always a great trick for me to control revs. Mike
hi all
thanks for the comments. i may go back and ask the dealer on this one, and see if there is anything that can be dobe. Cheers keith puer claudius |
Keith, take care what you say to them because of the g/box, warranty issues. 2.4 90 XS
Grockle
have already thought about that, but the chaps at stirling who i use are pretty good, and the have said that the warrenty will not be affected by what i have had done. i do not think it is a major issue, and it is something that i can live with, makes it easier to go up hills as i do not have to hold onto the hnad controls. thanks agian. Cheers keith puer claudius |
