Home > Technical > Unusual starter motor fault
An unusual fault for the forums technical panel to consider:
Ever since I bought it about 13 years ago, my TDCi has every once in a while behaved as though the battery is flat, i.e., when you turn the key to crank the engine you hear the start engage, the engine doesn't turn, the panel lights go out as with is a very heavy drain on the battery, and nothing else happens. Usually if you release the key and try again at about the third or fourth attempt it will crank with enthusiasm and start normally. If you measure the battery voltage it is always good (even if you do so immediately after it has done this and before starting the engine) so the battery is not, in fact, flat.
My assumption is that it is a starter or solenoid fault of some kind, but it has happened so infrequently that I have never got round to changing the starter (although I carry a spare just in case).
My battery is also the original fitted in 2007 by the factory, so it is 15 years old and has done 260k miles. It owes me nothing, and I am frankly amazed that it still performs as well as it does.
Earlier this week the failure-to-crank effect happened again, however on this occasion repeated attempts to crank didn't work. My immediate conclusion was that this time the battery had failed and I genuinely had a flat battery. Out with the jump leads, hook them up to another vehicle, and the Defender cranked and started immediately. More out of interest than anything else, I then disconnected the jump leads, shut down the engine, and measure the battery voltage - full charge. I tried starting the engine, and it cranked perfectly and at full speed and started. Five times in a row. My conclusion - not a flat battery but the same infrequent problem but this time more persistent.
So my puzzle now is what could be wrong with a starter motor that means that perhaps on 1 in 100 starts it fails to crank (with flat-battery-like symptoms) but cranks normally with a second battery in parallel (i.e., jump start configuration). I can think of faults which would cause the failure to crank, I can even think of some which would be negated by having two batteries in series (i.e., 24 Volts), but I can't think of any which would then be negated by having two batteries in parallel, the only difference being that twice the is current available, since this would seem to rule out impedance faults such as faulty solenoid contacts, or even stator or commutator windings.
It's a bit of a puzzle, and if anyone has either experience of anything similar or any ideas I would be fascinated to hear.
(The other possibility of course is that it is purely coincidental that connecting the second battery apparently made a difference and it was going to work on that attempt anyway. Until it does it again and I can again connect a second battery I won't know for sure, but I do now have a second battery in the back just in case).
Post #971237 15th Nov 2022 4:42pm
MK
In all those years have you changed the starter relay? Puma 110" SW
Post #971242 15th Nov 2022 6:16pm
No, and it wouldn't be my first suspect but no harm in trying next it happens.
Post #971243 15th Nov 2022 6:48pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Similar(?) problem in that my daughter recently flew over to France to drive a vehicle back to the UK for sale. You’ve guessed it, on the morning she was to leave, the click click click of a flat battery or a loose connection. The battery ISN’T easily got to on this model, it’s underneath the rear seats in front of the rear axle and only accessible from underneath. Push started easily, voltmeter showed charging at 14 odd volts, lights etc. working perfectly. Switch off, try the starter, click, click, click….
To cut a long story short, she drove to Calais, DFDS to Dover, it’s amazing how many guys volunteered to push-start a young girl driving a Morgan whenever she had to stop for petrol or drive off the ship.
She stopped off at the Morgan dealer in Kent, a faulty starter motor was diagnosed. They didn’t have one in stock, took one off a show-room vehicle on the understanding that when another one was sourced she’d return so they could swap them back.
New starter motor, switch on, click, click click. Starter motors exchanged, new battery fitted. Perfect! They’d checked the battery on the car with a Drop Tester, but somehow it was only failing when the full load of the starter motor was required.
Why not try running with another battery before changing relays, starter motor etc?
Peter
Post #971244 15th Nov 2022 7:06pm
It's certainly easier to change to battery than then starter (especially since I have underchassis protection). Odd though that it's happened for 13 years.
Post #971245 15th Nov 2022 7:20pm
If you do change battery I highly recommend Yuasa Silver. Very pleased with mine. KEEP CALM AND Drill ON
Post #971246 15th Nov 2022 7:21pm
I have a Varta LED95 EFB standing by if needed.
On reflection I don't think it can possibly be a relay fault because the starter is engaging and attempting to crank. Not only can your hear it doing this but the voltage drop caused by the stalled motor (no back emf) browns out the other electrical systems. The relay must therefore be energising correctly.
Post #971254 15th Nov 2022 8:05pm
High resistance in the ignition switch, perhaps? It sounds very similar to when my switch failed and there was evidence of excessive heat on one of the contacts:
 Darren
Post #971264 15th Nov 2022 9:05pm
Again I could understand a fault with the switch leading to a failure of the starter to engage, but not to a fully-engaged but non-cranking starter.
Post #971265 15th Nov 2022 9:12pm
Retroanaconda
I had this on a Tdi years ago. I never solved it despite changing the starter and the battery, it was always sporadic. I can only surmise it was a poor connection on the solenoid or something.
Post #971266 15th Nov 2022 9:26pm
Honestly, what you're describing sounds exactly like what I experienced. Turn the key and there's a brief lurch as it tries to start and then nothing - all lights out as if a dead short. It got progressively worse over several months until it failed completely.
It seems to me that connecting a second battery might give enough oomph (technical term) to overcome any high resistance and, of course, once it's started the problem goes away. Darren
Post #971267 15th Nov 2022 9:29pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I've got a lucas m79 from a metro that sounds like its doing the same thing. (The engine is on the floor on a pallet) Jumping the start terminal it is spinning up but the solenoid isn't pushing the drive out far enough to mesh with the flywheel - in my case the lever connecting the two is partly seized. Maybe yours is too. 1953 80"
1987 mini city e
2011 90"
Post #971268 15th Nov 2022 9:31pm
^ Presumably in this case you hear the starter spinning, which I don't.
LRA, did a new starter fix your problem?
Post #971275 15th Nov 2022 10:51pm
Dinnu
Do the lights on the dash go completely out, or they dim?
If there is such a voltage drop (as you say due to no back emf from the starter not spinning), would that not draw enough power from the solenoid, triggering the click click click sound as the power to the solenoid is restored when the solenoid itself remove the power to the starter?
So if the dash lights are going off, perhaps there is a voltage threshold that the lights can operate at (I do not know if the lights in dash are leds or old incandescents. Unless it is designed to cut off power from everything else except the ecu and the starter itself during cranking. Though that I do not know either. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #971276 15th Nov 2022 11:56pm
No, it was a new ignition switch. Darren
Post #971279 16th Nov 2022 6:54am
